Need expert help
roadie114
Need expert help
Post by roadie114 »
Ok guys, I have an '87 Elite 80 that came with tubed tires. The rims are stamped tubeless and can run them, so I purchased 3x10 tubeless tires. Now I just need to know what size tubeless valve stem to purchase that will fit. Any ideas? I called my local Kragen and they carry two sizes, .45 and .6. No idea if those are compatible. Any help would be appreciated, thx!!
mookie
Re: Need expert help
Post by mookie »
there is a lot i don't know but can't you go to a bike shop and simply but tubeless stems.have the shop measure if there is a question about what to use.
are you going to put the tires on yourself? if not let the shop get the tire to hold air...
busting my knuckles on vices since
for long as i can remember
chevyguyjay
Post by chevyguyjay »
go to murrays, or autozone. they sell valve stems there. i did that to an elite 80 i worked on a few months ago. its like $6 for a package of 4. 8)
~2004 Geely Fashion~
roadie114
Post by roadie114 »
Sweet, thanks guys!!
roadie114
Post by roadie114 »
chevyguyjay wrote:go to murrays, or autozone. they sell valve stems there. i did that to an elite 80 i worked on a few months ago. its like $6 for a package of 4. 8)
Do you remember what size you purchased?
Alarmnbob
Post by Alarmnbob »
Measure the hole in the rim. The valve stems go by hole size. 11.3 mm is standard for my 125 Elite and Helix
I would believe it to be the same on the 80cc. 11.3 mm is .05 inches so either .45 or .6 with a good rubber seal will work as long as it fits the hole.
86 Honda Helix, 1995 Honda Helix, 2004 Helix Clone
87 Honda Elite 150, 88 Elite ES , 1999 Itajet Dragster
86 Honda Aero 125 , 2004 Honda Elite 80
2002 Yamaha Vino"ROCKET"
roadie114
Post by roadie114 »
Alarmnbob wrote:Measure the hole in the rim. The valve stems go by hole size. 11.3 mm is standard for my 125 Elite and Helix
Found Slime ones at Autozone so I purchased both sizes.
It seems to me there'd be a good living to be made selling valve stems that have a 90-degree kink in them so that gauges and fittings can be applied to the valve without having to clear the wheel hub. My front tube has such a valve, but my tubeless rear Met wheel does not. If the valve stem protrudes much more than a half-inch, it's hard to attach the pump. Links, anyone?
http://www.prestigewheel.com/Image2994.asp
http://www.oldbikebarn.com/K-L-Tire-Val ... nda-Street#
mookie
Post by mookie »
http://www.powersportrider.com/CGI-BIN/ ... age=179.00
part number 37-0107
Tucker Rocky- at any shop
mcbridew
Post by mcbridew »
I was looking to change my oil in my 87 Elite scooter and opened up the wrong screw on the bottom. It is a bolt with a long spring and then a round like cylinder. I need to find out how to put it back in. In what order.
veedubh20
Post by veedubh20 »
you can go to any tire stores, and employee give free stems :lol: I got from lex brodie tires
bakaracer
Post by bakaracer »
I got these for sale.they are anodized
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
bakaracer
Post by bakaracer »
Wheelman-111 wrote:Greetings:
Did you find those 90 deg vales yet?
91 yamaha tzr 250r
maddog
Post by maddog »
you can get a smoother ride if you run tubes.
maddog
Post by maddog »
and you can get tubes in both 90 deg. long & short stem :smile:
