Found this on EBAY (Spree Carbs)
Shelton
Post by Shelton »
Reason: Update title
uspmale
Re: Found this on EBAY (Spree Carbs)
Post by uspmale »
Those will not work on the Spree's.
Post by eliteguy50 »
uspmale wrote:Those will not work on the Spree's.
what are they, se50 carbs?
Lunytune
Post by Lunytune »
Gee Thanks. I've got winning bid on them. :confused:
I can see now, no flange on the manifold side. Maybe they fit moped?
Lunytune wrote:I can see now, no flange on the manifold side.
both of then have a flange, look to the center of the first picture. on another pic, you can see a manifold off to the side. maybe the mate? might help id what these are for.
Lunytune
Post by Lunytune »
I must not be looking at it right. But since I still have the lead bid, I may be finding out soon. Since I've got a Spree, Elite E, LX and AF16, they're bound to fit something. Maybe a Yamerhammer?
Lunytune
Post by Lunytune »
I WON the bid, $12.50 plus $8 shipping.
The photos were definitely tricky. Both carbs are clearly Spree, two bystarters and manifold. I don't need them just yet, but they seem to be in good shape, just need the standard cleaning. So they go in my TO-DO list for winter days.
bakaracer
Post by bakaracer »
they are se50 carbs
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
evilone
Post by evilone »
Says right in the description. "These are two 1987 Honda Elite scooter 50cc carburetors " = SE50.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Lunytune
Post by Lunytune »
Call them what you will. I have no idea what an SE50 carb look like, but know what I'm holding in my hand. They are definitely Honda Keihin, and well worth the price. The two carbs are not the same. One has the bystarter on the outside (as mounted) and forward toward the manifold, and the other on the inside, even with the throttle cable. One appears identical to the carb I pulled from my SB50, the other identical to an SA carb I bought off eBay last summer. The manifold has been polished silk smooth. It might go on my SB50 rebuild.
evilone
Post by evilone »
lunytune wrote:the other identical to an SA carb I bought off eBay last summer
Early (88-93) SA carb is same as SE. I should have said AF05 carbs. Sounds like you got 1 SB50 and 1 AF05. Now that i think about it, the Spree did have bystarter in different spot than my 87 AF05 Elite. I went back and looked at pic. Spree carb on left, AF05 carb on right. Spree carb has bystarter on outside, right? I know the AF05 carbs bystarter is on inside.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Lunytune
Post by Lunytune »
evilone, the photo was too dark to really tell a whole lot, and in fact the flange was hard to see. But now that I've got them in hand, I can see what they are. I just looked at a couple of scoots that I have covers pulled on, or could peak under, and one carb and manifold are near identical to the Spree and the SB. Other carb looks like the SA with bystarter on the inside. My SR (AF16E) also has bystarter on the inside.
If you will remember, there was a thread several months back about the many configurations of the AF05E, even with a non-variator and a variator powerplant both having AF05E designation. More Hondasan confusion. I'll also have some better idea when I tear down and see the jets. I expect a 68 in one and a 78 in the other.
