Wow, that big? I think the biggest I have is an 82. I guess a trip to the Honda store in in order.bakaracer wrote:Hey Ken before you ride that bike,make sure you up jet the carb.since you drilled out the exhaust,the engine is going to need more gas.If not its going to run lean and you will seize the engine.If planing on using the stock airbox,punch out the tab that covers up one of the holes on the inlet of the airbox cover.upjet to a 85 or 88 jet.
I have checked the variator, and the restictor plate is long gone. I was hitting ~ 35 on flats before I started mucking about. I'm hoping to get to 40-ish.
Ken
