AF05E Big Bore List - Aero and 88-93 elite Engines
Moderator: FAQ Moderator
Re: AF05E Big Bore List - Aero and 88-93 elite Engines
metrakit bore af05e http://www.metrakit.es/english/technica ... o=804H0220
Do you have to have your head modified to do this or do you just put the stock head on top of the channeled cylinder?Wheelman-111 wrote:Greetings:
Sorry that was confusing. Absolutely the Contesta kit is designed to re-use your stock head. In my case a channel was cut into it for use of a Corsa-type viton O-Ring. This makes head removal possible without sourcing spare head gaskets, and raises compression ratio for higher output. Premium fuel recommended.
It's official! I'm addicted
I had my head grooved - actually the scooter's - for the O-ring. Never seen the cylinder done that way.
Unlike the only spree kit that is available, you may just bolt on your original head with no modifications - so long as you use the correct provided head gasket.jk171282jk wrote:Do you have to have your head modified to do this or do you just put the stock head on top of the channeled cylinder?Wheelman-111 wrote:Greetings:
1993 Elite - The Mad Max
Just thought a gasketless cylinder would be more enjoyable to work on. I heard LSD really grooves your head
LSD? Are we talking scooters?jk171282jk wrote:Just thought a gasketless cylinder would be more enjoyable to work on. I heard LSD really grooves your head
Groovin' the Cylinder and Head
Replacing the base gasket with a Viton or Teflon O-ring is a great idea that never occurred to me. If there's enough space down there and the machine tool and skill set exists to carve a groove, it'd sure speed up the gasket-scraping process - AND avoid shreds dropping into the crankcase. Lapping the two surfaces together and using Copper Permatex worked for me, but an O-ring would probably be a more reliable seal.
As for the cylinder/head junction, I guess it's just a lot easier to carve on the head than the cylinder, but as long as the O-ring has a place to live, either would be fine.
Substituting an O-ring for the .02" thick gasket down below effectively lowers the ports, and so increases the static compression ratio two ways, considerably more than just O-ringing the head. Doing either mod, and especially if you do both, watch carefully for piston/head clearance issues. In my case, the Esteemed Scooterwerx machined a new combustion chamber in my stock head, as well as cutting the groove. 'Twas a thing of beauty, like all the machine work he does. I hope he remains available for future Scooter projects.
will these fit on all years of the aero?
I think the AFO5E came in 85+ Aeros, not the early ones but I'm not positive.
83 Honda Aero 80
Honda Aero80 and Aero50 parts for sale cheap.
http://www.hondaspree.net/phpBB3/viewto ... =2&t=15095
My Aero50 engine swap:
http://www.hondaspree.net/phpBB3/viewto ... 16&t=13021
can anyone else chime in on that i may be looking at buying one, but onle if i can up grade it. it is an 83
Im not sure if there is any kit available for the pre 85 aeros. or atleast none that are available in the US.jamadi112233 wrote:can anyone else chime in on that i may be looking at buying one, but onle if i can up grade it. it is an 83
'62 125cc Honda cub
'62 125cc Honda cub
