jb weld?
evilone
jb weld?
Post by evilone »
Is there anything that will stick to aluminum (scooter motor) and not be affected by gas/oil? I thought i saw a picture one time with a bead of :?: in crankcase used as a stuffer. JB Weld states "petroleum, chemical, and acid-resistent". BUT...use on fuel tanks, radiators, cracked engine blocks, etc. Places the JB Weld would be in contact with fuel, oil, and other chemicals.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Re: jb weld?
Post by evilone »
I was reading some more at JB Welds site and they say JB Stik is resistant to 300 degrees and...
The JB Weld that's in the 2 tubes is resistant to 500 degrees. The stik looks easier to use. So i'm assuming it's resistant to fuel and oil to 300 and 500 degrees depending on stik or tubes.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Bandit240
Re: jb weld?
Post by Bandit240 »
The 2 part JB Weld isn't that hard to use and works good. Ive used it to repair a radiator and a go-cart engine that had a crack in it. Worked fine both times. Clean the area well and mix it 1:1 and it will work wonders.
I once used it to stick about $5 worth of quarters to a cement walkway. Saw a fellow out there with a hammer and chisel trying to remove them. Most were still there, but the ones that were gone had cement still stuck them since there were little craters where they were.
1986 Honda Elite 150 Deluxe
1991 Yamaha XT600
1993 Honda Elite 80
2001 Honda Elite 50
novs86
Re: jb weld?
Post by novs86 »
Why? :?
I'd rather be riding my Aero!
evilone
Re: jb weld?
Post by evilone »
Bandit240 wrote:I once used it to stick about $5 worth of quarters to a cement walkway. Saw a fellow out there with a hammer and chisel trying to remove them. Most were still there, but the ones that were gone had cement still stuck them since there were little craters where they were.
:bowrofl:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
DaylightDies
Re: jb weld?
Post by DaylightDies »
Ive used it on a plastic Gas tank on a go-ped. It should work well on an engine casing. If JB weld cant do it, nothing can!
Besides its a cheap alternative to a new one!
'98 Yamaha Jog Cy50k
'96 "Frankenstein" Japanese Jog Cy50
JB
For a reliable bond, wash with solvent a couple times, then hit it with a clean rag soaked in acetone. Make sure the acetone is completely gone before applying the JB Weld, but it's not like that takes very long.
Solvents may nibble at the edges of the bond, but the scooter will be deep in a landfill before that's a problem for you. 2-part outperforms the stick by a mile. You can't roll the stick without getting some skin oils kneaded into it.
The sidewalk quarter caper is high-laryngeous. (I laughed out loud.)
dem0nk1d
Re: jb weld?
Post by dem0nk1d »
"Like I tell people all the time Speed cost money ..if you have to ask how much then most times your not going to do it !" -tru72
--\\\Projects\\--
95 Elite Restore Project for Wife
1982 Honda Passport
2013 Honda PCX 150
drizzle
Re: jb weld?
Post by drizzle »
another JB weld question-
will it work for adding a mounting bracket on an exhaust to bolt to the case? or will it get too hot? the exhaust i just bought has no mounting brackets, so i'm exploring my options.
dem0nk1d
Re: jb weld?
Post by dem0nk1d »
no that will not work. to much vibration will rattle it loose or snap your jb weld job.
--\\\Projects\\--
1982 Honda Passport
2013 Honda PCX 150
redrocket
Re: jb weld?
Post by redrocket »
i used jb weld when my crank stripped all the splines on it to weld the pulley on i hope that makes sense it worked it was hard and a mess but held me over till i got a new crank
evilone
Re: jb weld?
Post by evilone »
redrocket wrote:i used jb weld when my crank stripped all the splines on it to weld the pulley on i hope that makes sense it worked it was hard and a mess but held me over till i got a new crank
I know exactly what you're talking about. Same thing happened to the 87 elite i bought, i just don't have the desire to fix it. I got other projects.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Re: jb weld?
Post by evilone »
dem0nk1d wrote:http://www.markingpendepot.com/browsepr ... -2%29.HTML
Devcon Liquid Aluminum
Looks good. Too bad minimum size is 1 pound and almost $50 bucks.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
dem0nk1d
Re: jb weld?
Post by dem0nk1d »
Oh heck no it isn't, look around online you can get Devcon in a small tube that's less than the 1lb tub.
--\\\Projects\\--
1982 Honda Passport
2013 Honda PCX 150
evilone
Re: jb weld?
Post by evilone »
Will do :thumbwink:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
