PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
evilone
Re: PLEASE HELP!!!!
Post by evilone »
martynkim wrote: I also bought a brand new battery, Installed it and I got the same thing as before.
Still making me think it's the cover binding on drive pulley.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Re: PLEASE HELP!!!!
Post by martynkim »
Yes the side cover bolts are starting to snap. I am in Washington State.
martynkim
Re: PLEASE HELP!!!!
Post by martynkim »
Here is a picture
evilone
Re: PLEASE HELP!!!!
Post by evilone »
Ouch, that aint right. I'll give you my good cover if you pay shipping, should be under $10 i'd think.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Re: PLEASE HELP!!!!
Post by martynkim »
and another
martynkim
Re: PLEASE HELP!!!!
Post by martynkim »
Well I can't pass that up. Could I paypal you?
evilone
Re: PLEASE HELP!!!!
Post by evilone »
I sent a pm.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Re: PLEASE HELP!!!!
Post by evilone »
And just a note, the pic of your "half moon gear" is a little off from aerorobs pics. Might be problem?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Re: PLEASE HELP!!!!
Post by martynkim »
If I put the gear in that position OH #$%^ now I get it! (I hope)
evilone
Re: PLEASE HELP!!!!
Post by evilone »
I'm out for the night, good luck!
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Re: PLEASE HELP!!!!
Post by martynkim »
I will send ya an email if I need the cover and thanks!
aerorob
Re: PLEASE HELP!!!!
Post by aerorob »
how did that work when you got that half moon gear on right?
and make sure you have the little c clip on the outside of the cover where the kickstart spindle comes out of the cover. it keeps the kick start assembly from making its way into the drive pulley
evilone
Re: PLEASE HELP!!!!
Post by evilone »
I didn't have parts in hand in previous posts but i noticed aerorobs pics are wrong. Pics below are of the 87 elite cover and an 01 elite cover. the clip type thing needs to be OVER the post, not next to it. Hope this makes it work.
01 elite cover
87 elite cover. NOTE WHERE FIRST TOOTH IS ON THE RIGHT SIDE OF GEAR (pointing right at post. And make sure that clip type spring on small gear is OVER that other post
both covers
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
aerorob
Re: PLEASE HELP!!!!
Post by aerorob »
thanks evilone. i didnt every notice that till you mentioned it. ill fix that next time i switch my rollers out. my kickstart seems to be un affected by the position of that horseshoe shapped thing though, luckily enough... when my kickstart assembly blew up i had a difficult time getting all the parts back where they were supposed to. the half moon gear has a blank spot on the tooth edge where the teeth are not cut in and he needs to put that spot on top of the kick gear instead of under it.
sorry for the bad picture :oops:
martynkim
Re: PLEASE HELP!!!!
Post by martynkim »
Hey thanks for the pictures and explaination. I haven't worked on it yet, just got home from work. I picked up some new bolts at Lowe's and have my borrowed ez-out in hand. I will let you know how it goes when I get the chance to work on it tonight/tomorrow.
