PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
evilone
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
Post by evilone »
martynkim wrote:Yup it stopped smoking has a little hesitation accelerates great rode it for about 20 minutes it just won't idle :love:
Won't idle? I don't want to go through the 9 pages of thread to check, but did you clean the crap out of pilot jet?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
aerorob
Post by aerorob »
he said he cleaned the carb, but the pilot jet is easily missed if he doesnt know what to look for.
to clean your pilot you need the smallest guitar string, carb clean, some compressed air.
martynkim
Post by martynkim »
Pilot jet??? I split the case removed all the screws float rubber threw it into a container full of carb cleaner let it sit overnight then blew an entire can of cleaner thru it blew it out with compressed air the more it runs the better it is getting. sometimes it won't start but if you walk away for awile 3-5 min it starts right up
martynkim
Post by martynkim »
Still smokin comes and goes depends how hot the engine is. Hoping it will burn off
aerorob
Post by aerorob »
yeah that is alot of oil you are buring off. is it starting to go away or is it contunuing?
martynkim
Post by martynkim »
It comes and goes depends how warm the engine is
martynkim
Post by martynkim »
BTW I don't even know where or what the pilot jet is... :newb:
aerorob
Post by aerorob »
tiny little brass tube that sticks out like the main jet tube, but its about a quarter the diameter. runs parralell of the main jet tube. you need a guitar string of the smallest size to be able to get it through the hole. that gives you your fuel for idle.
martynkim
Post by martynkim »
I was looking for that but I didn't notice it. I seen them on different carbs before, I wouldn't think it was missing. :?
aerorob
Post by aerorob »
if your scooter is starting, im sure it is not missing. the pilot jet getting cleaned is worth enough to remove your carb to clean it.
i got this picture from this forum and labeled pilot jet. that will give you all sorts of issues.
martynkim
Post by martynkim »
Yup that's what I was talking about.
martynkim
Post by martynkim »
I blew cleaner thru it and air.
aerorob
Post by aerorob »
good. will it idle now? and have you gotten a new air filter element yet?
martynkim
Post by martynkim »
No, I did that initially. And the filter won't be here till wed-thurs
evilone
Post by evilone »
Did you clean the hole in bowl out good too? pic borrowed from http://www.hondaspree.net/phpBB3/viewto ... f=5&t=8786
If it's clean you will be able to go into a very dark room and shine flashlight down the hole and see the light at that small hole in bowl.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
