Won't idle? I don't want to go through the 9 pages of thread to check, but did you clean the crap out of pilot jet?martynkim wrote:Yup it stopped smoking has a little hesitation accelerates great rode it for about 20 minutes it just won't idle
PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
he said he cleaned the carb, but the pilot jet is easily missed if he doesnt know what to look for.
to clean your pilot you need the smallest guitar string, carb clean, some compressed air.
- martynkim
Pilot jet??? I split the case removed all the screws float rubber threw it into a container full of carb cleaner let it sit overnight then blew an entire can of cleaner thru it blew it out with compressed air the more it runs the better it is getting. sometimes it won't start but if you walk away for awile 3-5 min it starts right up
- martynkim
Still smokin comes and goes depends how hot the engine is. Hoping it will burn off
- phppBoxbsPM.jpg (18.76 KiB) Viewed 6197 times
yeah that is alot of oil you are buring off. is it starting to go away or is it contunuing?
- martynkim
It comes and goes depends how warm the engine is
- martynkim
BTW I don't even know where or what the pilot jet is...
tiny little brass tube that sticks out like the main jet tube, but its about a quarter the diameter. runs parralell of the main jet tube. you need a guitar string of the smallest size to be able to get it through the hole. that gives you your fuel for idle.
- martynkim
I was looking for that but I didn't notice it. I seen them on different carbs before, I wouldn't think it was missing.
if your scooter is starting, im sure it is not missing. the pilot jet getting cleaned is worth enough to remove your carb to clean it.
i got this picture from this forum and labeled pilot jet. that will give you all sorts of issues.
- snv31880.jpg (46.84 KiB) Viewed 6120 times
- martynkim
Yup that's what I was talking about.
- martynkim
I blew cleaner thru it and air.
good. will it idle now? and have you gotten a new air filter element yet?
- martynkim
No, I did that initially. And the filter won't be here till wed-thurs
Did you clean the hole in bowl out good too? pic borrowed from http://www.hondaspree.net/phpBB3/viewto ... f=5&t=8786
If it's clean you will be able to go into a very dark room and shine flashlight down the hole and see the light at that small hole in bowl.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
