PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
martynkim
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
Post by martynkim »
Ok, I get it, I need to go to a music store get a string. and blow er out again. I'll do that tomorrow. :newb:
evilone
Post by evilone »
I'm not sure if the smallest guitar string will fit in the hole in fuel bowl as well as pilot jet. If not i think i used a needle to dislodge some gunk. Make sure you check it in dark room with flashlight.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
I'll stick something in there :idea:
martynkim
Post by martynkim »
Couldn't find a music store today so I just did some painting check the wheels Grey & Red :thumbsup:
martynkim
Post by martynkim »
I hope this is what I was supposed to do. :newb:
That wire is going through your main jet. You can unscrew it with a flat screwdriver - make sure not to force a tapered one against the cast aluminum walls of the tower. Get one that's the same diameter as the screwdriver head. Then remove the jet and push the emulsion tube out from the topside of the carb with a matchstick or other non-metallic pushing instrument. Clean all that by soaking in solvent - preferably acetone, MEK or commercial carb dip.
The pilot circuit is the smaller brass standpipe below the main jet tower in your pic. That hole is likely even smaller than your "E" guitar string. It's also the culprit for many, many idle and throttle-refusal issues.
martynkim
Post by martynkim »
I wondered as I felt no resistance putting it in basically, I think I cleaned nothing. Although I removed the kickcover AGAIN and I am happy to report it is 100% functional BIG THANKS AGAIN TO EVILONE!!! :hi:
martynkim
Post by martynkim »
Well I didn't see wheelman's post until it was back together. So....... It still runs like crap,I guess I will take apart again :jack:
evilone
Post by evilone »
It only works when you stick in in the right hole :oops: :lol:
I found chopsticks from local chinese take-out works great for pushing out the e-tube after removing the main jet.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
nacree
Post by nacree »
Do yourself a favor and remove that black o-ring gasket around the base of the carb as well as the float and needle and soak the entire carb in acetone overnight.
I have never had that method fail to clean up the most fouled up carb and it beats having to take the carb off seventeen times.
martynkim
Post by martynkim »
Ok, so I removed the jet and cleaned the living * out of it. Acceleration is awesome and improved. :coolcruise: Still very hard to start I have to place my hand over the carb to make it start. :*: Still does not idle. Runs awesome :coolcruise: just starting and idle. I tried to adjust the idle it makes no difference when I turn the screws. :*: Please Help!!!
You're very close. Do as Nacree suggests, but make the soak 2-3 days with vigorous agitation every time you walk by. The have a close look at the Pilot hole over the second, smaller brass standpipe. That and/or the bystarter mini-jet are likely still clogged.
Nice job fixing your kickstart! If you can fix that you can unclog your carb. Patience.
martynkim
Post by martynkim »
Ok I don't have any acetone on Hand. :sad: I could go get some but I do have some laquer thinner and some denatured alcohol on hand what about using either of those. :wink: Oh and I can't get MEK in washington state :*: some new "green" law.
martynkim
Post by martynkim »
BTW Can I remove the pilot circuit for cleaning as well :?: How does it come apart :?:
Pilot Error
Legend has it that certain Carburetor gods :wink: have successfully removed the pressed-in brass Pilot standpipe. Mere mortals would be unwise to attempt it, as special tools are required to hold the pipe without crushing it. The "Jet" for the pilot circuit of the tiny PA carb is actually cast into the carb body and cannot be removed. The same goes for the float needle seat, despite Service Manual instructions to "...always replace the needle and seat 'as a set'."
Cleaning this pilot hole with a metal probe requires discretion, as its size is critical to idle performance with the stock airbox setup. I used a single bristle plucked from a steel brush held in a hemostat to scrape around the sides. (need really good near visioin or magnifier...) The thin diameter and flexibility of the bristle prevented gouging and scoring that pinhole. There's a thread somewhere showing the Legendary Pinhole. You can be sure Wheelman didn't take that excellent close-up pic. :oops:
