PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
martynkim
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
Post by martynkim »
Like this?
That looks like a crushed brass standpipe alright. However the pic quality is clearly better than any I have taken. :oops:
martynkim
Post by martynkim »
Well with the exception of blowing the most toxic substance known to man thru this carb ,I think I have done all of the suggestions that all of you have made. I think prehaps this carb is done for If I could adjust the cable to pull on the throttle slightly, I might be able to deal with the situation. I guess I am on the hunt for a new carb :x :evil:
evilone
Post by evilone »
Not sure if i missed it, but did you do the guitar string down pilot jet?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
Oh yes, several times. :( Gave it a bath in Carb clean then in acetone. Blew it out with compressed air. :eyeroll: loved it :love: hated it :evil: threw it across the room. replaced the float & needle. threw it again. :twisted: :*: IDK what is wrong with it.
martynkim
Post by martynkim »
After I got mad at the Elite I just had to ride something that ran good. Took out my neglected Spree for a romp. God, it feels so small now and actually underpowered. But, I still love it :lol:
martynkim
Post by martynkim »
Well, I guess I'm gonna try it one more time today. tear it all down :|
odinxxix
Post by odinxxix »
wait...are you not able to twist the throttle? that is an adjustment in front of the bike just under the twist grip. should be 1/8 to 1/4 inch of play.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
martynkim
Post by martynkim »
I can twist the throttle it is sticky though. If I could take up some slack in the cable it may idle. :hi:
evilone
Post by evilone »
Check your pm's
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
Man, what a long day :bs: . After the wife's day surgery honda called me to tell me the air filter I ordered was in. I raced down there to get it before they closed. :D Came home and installed it. Still hard to start and it isn't too cold outside 45 degrees and she's been living in the house. :werd: still won't idle but, now I noticed while on the stand if I peg the throttle you hear it kinda misfire occasionally. Kinda a lower burr sound. That carb's gotta be dirty still. :(
martynkim
Post by martynkim »
Well I went ahead and ordered a main jet for it today. $6 from Honorable Hondasan. I'm hoping I can smooth this thing out and get it to idle :)
odinxxix
Post by odinxxix »
what is stock jet in your SE50? if you havent done any mods stick with that. sounds like to me maybe your carb is still dirty,or your settings are not on the money. before you go messing wit hjets id look at those . d/load the manual b4 you mess with jets.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
martynkim
Post by martynkim »
Just replacing it with stock. I don't know if it is different than stock I'm just trying to figure this thing out. :newb:
odinxxix
Post by odinxxix »
look at your stock jet before you order. you might look at the main needle and see if it is set in the middle spot. i wouldnt think anything would br wrong with the main jet.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
