honda elite 150 SpaCE InVaDER
miller95
Post by miller95 »
honda elite 150
26 xxx kms
Parts replaced so far : none
Looking to:
upgrade carb
new K n N custom filter
new throttle cable
newer fenders (red)
Custom exhaust
Took my air filter off the other day and noticed some oil in the air box, what would be the raeason for this?
More pics to follow
scooter side.jpg (45.59 KiB) Viewed 12972 times
miller95
Re: hond elite 150
Post by miller95 »
more pics, some blue overspray all over the scooter looks horrible, some kid that had it before me was a little heavy on the spray cans.
and what is this hose?  must i have it connected to the air box?
this hose coming from the carb, is this just a vent hose?
miller95
Re: hond elite 150
Post by miller95 »
more
another set of fenders I picked up for $40
old fenders, horrible paint job some kid done
old fender black.jpg (38.45 KiB) Viewed 12966 times
bigluelok
Re: hond elite 150
Post by bigluelok »
too much oil could be the cause of the oil in the air box.
CH80
Clivester
Re: honda elite 150 SpaCE InVaDER
Post by Clivester »
There should be 2 breather hoses going to the airbox - one on the front from the crankcase, and the other at the back from the transmission case (your mystery hose). Either could be the source of the oil. However, its most likely from the crankcase as that's more prone to positive pressure. If the oil is dark and "carbony" its probably engine oil, either from overfill or blowback. How's the compression?
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
miller95
Post by miller95 »
yeah i think i might of overfilled the oil. Seems to be lots of copression, although i never used a tester on it yet.
elitedio
Post by elitedio »
There is a oil drain that has a plastic cap on the bottom of the bike on the right side. You should drain it of any excess oil. It is part of the recirculation emissions control and is meant to be drained periodically. If it is full it will spew the oil into the engine through the intake system. As the engine ages you will get more.
1989 Elite E with 86cc Dio
miller95
Post by miller95 »
Thanks alot guys for the help. Also how hard is it to replace the throttle cable? This is my first scooter and my first time ever doing work on one. Usually working on quads.
miller95
Post by miller95 »
is it necessary for my 2 hoses to be connected to air box? or is it alright for them to be vented to atmosphere? thanks guys.
bigluelok
Post by bigluelok »
i dont know if you have it already but here is the 85-86 150 manual
http://www.hondaspree.net/other/Elite_C ... _85-86.pdf
CH80
Clivester
Post by Clivester »
miller95 wrote:is it necessary for my 2 hoses to be connected to air box? or is it alright for them to be vented to atmosphere? thanks guys.
You could vent to atmosphere, with the following considerations:
  • may need an oil trap on crankcase vent to avoid splashed oil
  • should probably put a small dust filter on the transmission vent
  • holes in the airbox should be plugged
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
miller95
Post by miller95 »
hey guys, I have my gas tank took off the bike, whats the best way to check it for leaks?
Clivester
Post by Clivester »
Get a big bucket of water large enough to completely submerge the gas tank.
Have the gas cap, fuel sender cap installed on the tank, but remove the petcock. Try to find a rubber bung that will fit over a bicycle tire pump on one end, and seal into the petcock hole at the other end.
While the tank is fully submerged in water, pump the tire pump to create some air pressure in the tank (only a few PSI). You will see air bubbles emerge from any leaky areas.
You may need to seal the gas cap air vent with your finger to create enough air pressure.
Precautionary notes:
make sure the tank is empty and preferably air dried and don't try to do this while smoking. Failure to heed these warnings could make an impressive flamethrower!
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
miller95
Post by miller95 »
hey guys almost done, heres a sneak peak.
Yes I know the rims are hideous, new ones, or new paint coming soon.
bigluelok
Post by bigluelok »
nice i love elite 150's
CH80
