PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
martynkim
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
Post by martynkim »
Well the picture tells the story I agree it looks damaged. I don't recall it being that way.
evilone
Post by evilone »
I'm not sure but maybe your spree carb fuel bowl will fit, at least to test it.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
Good idea but, Spree runs perfect I don't want to muck it up. If it ain't broke don't fix it :werd:
evilone
Post by evilone »
Oh, i thought you were parting it out. Leave it alone then. Send me your address again and i'll send a gasket to see if that's the problem.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
No, I got a couple of Sprees an express a QT 50 the collection is growing.
chevy1966
Post by chevy1966 »
pull the plug try spinning the motor over see if anything comes out of the spark plug holethe previuos owner may have got too much gas and oil in the motor
martynkim
Post by martynkim »
Yeah I did that the motor was full of oil I resolved that problem but, thanks!
evilone
Post by evilone »
I'm sending a carb and throttle cable to martynkim. Anyone know why my SE50P carb comes with a #85 main jet but the SE50 comes with a #82 main? Is it because of the restricted exhaust?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Could some P.O. Have swapped jets? Stock on a lot of "P" models was 68.
Maybe the p/o did some de-restricting and upjetting - or a swap to a SE50 carb?
The Service manual says its an #82 on the SE50P... Carb tag is PA31D for the 50P, PA31 E for the non-restricted.
martynkim
Post by martynkim »
I just got in my replacement jet. I can't tell you what # it is but here is the P/N 99101-1870820
"0820" = 82.
martynkim
Post by martynkim »
So, I should use my new one :wink:
evilone
Post by evilone »
Funny, i look on cyclepartsnation and it's switched around...se50 = #82 and se50p = #85. My carb is off an se50p and has the #85. martynkim got a replacement jet and it's a #82? I can't check the carb tag, it's in the mail on the way to martynkim :wink:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
It wouldn't be the first time that a parts bin spilled into another. The incorrect jet fits just as easily as the correct one. If Assembly Line Worker Mitsuko doesn't physically inspect the jet before screwing it, the customer gets a very rich-running "P"-model. Intuitively, a bigger jet specified for a lower-revving restricted-exhaust scooter sounds like a specs table typo. It wouldn't be the first time that happened either!
