PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
evilone
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
Post by evilone »
Like mousewheels said, owners manual says SE50 is #85 and SE50P is #82. Funny how cyclepartsnation.com lists it backwards and so does mrcycles.com only mrcycles.com has #85 and #82 listed under 87 SE50P.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
evilone wrote:Like mousewheels said, owners manual says SE50 is #85 and SE50P is #82. Funny how cyclepartsnation.com lists it backwards and so does mrcycles.com only mrcycles.com has #85 and #82 listed under 87 SE50P.
I don't even know the difference in these models what do I have? :newb:
martynkim
Post by martynkim »
And you know what after this thing is idling and doing what it should how do I make it go FASTER???
evilone
Post by evilone »
martynkim wrote:I don't even know the difference in these models what do I have?
:lol: I was going to ask which model you had but figured someone would reply "SE50...it's in the title of thread". Look under your seat and see if there is a sticker with model # on it. Could you post a pic of your exhaust pipe? How fast are you looking to go?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
How fast? as fast as possible!!!
evilone
Post by evilone »
martynkim wrote:How fast? as fast as possible!!!
I thought you'd say that :). I got mine to 47 mph in modified stock form or you can go over 60 mph with aftermarket parts, i'll let wheelman tell you about the aftermarket path.
Did you find out what model you have?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
martynkim
Post by martynkim »
SE 50P
martynkim
Post by martynkim »
Pic of the exhaust
martynkim
Post by martynkim »
Pic of the sticker which one is better?
martynkim wrote:Pic of the sticker which one is better?
The SE50P is restricted. Muffler, variator and a different final reduction are some differences to make it slower.
An interesting thing about the jets and SE50P's I found - there are 2 flavors of 50P. Restricted, and Really Restricted (Iowa).
SE50P A AF121*HS000001 to HS 012411 uses an #85 jet, Carb Tag PA31E
SE50P AA AF122*HS000001 to HS002000 (Iowa) uses the #82 jet, Carb Tag PA31K
Check out your VIN tag and find out what SE50P you've got, but odds are you dodged the Iowa bullet.
martynkim
Post by martynkim »
1217hs006447 that shouldn't be the Iowa one :crazy:
martynkim
Post by martynkim »
ASo I need a new variator muffler? To make more speed?
odinxxix
Post by odinxxix »
variator muffler?
vari yes
muffler yes
gears yes
just be ready to retune everything
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
martynkim
Post by martynkim »
yeah that's what I meant. what is the biggest bang for the buck to start?
evilone
Post by evilone »
martynkim wrote:yeah that's what I meant. what is the biggest bang for the buck to start?
Variator...get a keli. Daywot on Ebay. Tell him you need a ramp plate too (around $10 for plate)
Muffler...get a stock SE50 pipe...performance if you go big bore.
Gears...i got 47 mph using SE50P gears.
I didn't know about the 10:1 gears at the time.
and i'm not sure what tooth ratio makes 10:1. The SE50 driveshaft is 12 teeth and the SE50P driveshaft is 13 teeth. Maybe that's the 10:1.
I recommend stock SE50 pipe. chevyguyjay bought a new Proma from me and performance was not anything to talk about. His SE50 pipe was modified, i'll give him a call and see if he still has it. He might sell it.
Heres a pipe on Ebay that you need. Ummmm looks like you get all 4 of them! See how the head pipe gets bigger before going into muffler? Now look at yours....skinny all the way (your pic didn't show head pipe). http://cgi.ebay.com/ebaymotors/H-496-HO ... mainQ5f210
Your variator most likely has a flat ramp plate unless someone replaced that. The SE50 ramp plate isn't flat which pushes belt higher for more top end. Keli variator pushes belt even higher for more top end and if previous owner swapped flat ramp plate for SE50 plate, you can use stock plate in a Keli.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
