Spree - Aftermarket transmission gear installation
This is the repository for hop-ups and mods for Elite and Spree. Look here for information on exhausts, porting, cylinders, intakes, and suspension mods.
Moderator: FAQ Moderator
odinxxix
Post by odinxxix »
thanks i dont have access to post there. ok i had rear gear installed when i thought and it was suggested that i do a write up. ill get you up to the install.
step
1. remove rear plastics,rear fender and exhaust.
2 remove belt/kicker cover this will expose the 2 pulleys you will have to remove.
3. find a tool to hold the clutch pulley(i use this)
4 remove the nut for the tire and the nut holding the clutch bell. use the same toll to hold the front pulley and remove that nut. pull off the 2 pulleys and belt as one(much easier)
5. now remove the remaining bolt holding the gear cover on and lightly tap the cover til the seal is broken the slide the cover off the shaft. o this is a good time to have a pan ready to catch the oil that will leak out from the case. take a break get a drink grab a smoke if you do.
6. clean the cover and case well with a razor knife and some brake clean. make sure they are as clean as you can get them.
7. ok ready to install..right? ok install the large gear should look like this
8.install thin washer.like this
9. install the smaller gear like this
10. ok now its time to install the gear cover since they are discontinued parts you will need some silicone
Reason: Update subject title for easier searching
odinxxix
Re: taz gear install(MODS please move to tech)
Post by odinxxix »
i used this
11. carefully replace the gear cover like so.
12. put in the inner 2 bolts and the 2 outer bolts
13. replace the rear fender should look like this
14replace pulleys,make sure when you put on belt the it goes on the "hub" of the front pulley
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
odinxxix
Post by odinxxix »
15. replace the front outer pulley make sure that you put on that washer or you will crush the splines
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
odinxxix
Post by odinxxix »
16 use the same tool that you used to hold the pulleys and use it to help tighten.
17 replace tire and tighten the nut there.
18. fill this hole with 3OZ of 10W-30 motor oil(i used royal purple syn oil)
19. replace the belt/kicker cover and tighten all those bolts. i gave the rear tire a few spins to cover the gears.
replace the fender,exhaust and rear plastics,seat and turn signals. clean up and stand back and thank yourself for a job well done, start and enjoy.!! if you hear a whinning noise taz suggests removing that thin washer behind the small gear. i did and it got louder for me so test before you add the oil. hope this helps all of you about to enjoy the up gear.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
odinxxix
Post by odinxxix »
this pic goes with step 9 sorry forgot to add
edit: mousewheels - this pic has been added to step 9
bradthreee
Post by bradthreee »
Dont know if it makes any difference but the dealer recommends using motorcycle oil in the gearbox
Re: Spree - Aftermarket transmission gear installation
Nice post, Two-Niner. Great pics, and I should know. :oops:
One concern:
i used this
[Pic of transmission case cover nicely prepped with Permatex.]
Since there have been a couple of posts describing "Whirring" after the upgear installation, this may provide the reason. Y'see the gasket isn't just for sealin'. Its thickness is calculated into the final assembly of these high-precision parts. Permatex may do an admirable job of holding the oil in the cavity. However when you tighten down the cover bolts, it crushes down to nearly-nothing. That ~mm of gasket thickness is gone, so there is a good chance that the countershaft will be pinched end-to-end. A similar issue regarding the starter Bendix arose about a year ago: You can't install the belt cover without either a gasket or some shimmage to prevent the same shaft-pinching issue there.
Check that transmission countershaft and axle shaft for signs of heat-darkening. Also check the cover and the crankcase side to see if the gears have shaved off some aluminum.
If the gasket really has been discontinued by Honda, a better solution would be to make one out of Autoparts gasket material. I'll bet that doing so resolves the noise issue. Slathering both sides of your new Honda or Homemade gasket increases the odds that you'll be able to re-use if you ever must disassemble again.
Ugg. "Discontinued" gaskets again.
Call some other shops. Metro Powersports in Canton, MI (Honda dealer) can cut any Honda gasket on an as-needed basis. Seems extreme, but might be worth giving them a call if all else fails. There may be someone closer to you that can do the same thing.
Admin, Hondaspree.net
