reccomend me a street tire
94cruiser
Post by 94cruiser »
Please recommend me a street tire.
My scoot has a little over 5000 miles and the rear tire is worn out.
I will ride it all summer long in dry and wet weather but will not take it off road.
The stock tire has a tube, right?
What's the pro/con of tubless?
I do have a leak now (from the valve where it meets the rim).
I remember days I had to pump it up in the morning and in afternoon leaving work, then days where I did not need to pump at all.
After wintertime storage it was all flat.
:hi:
2000 Elite SA50
stock
odinxxix
Re: reccomend me a street tire
Post by odinxxix »
http://www.americanmototire.com/catalog ... Path=33_61
go here for tires good prices, since you have a 2000 SA50 like i do. your will have tubes, you need to keep the tubes or the tubeless tire may fail on the rim. so you can either get tube type tires or get tubless and use the tube anyway.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
martynkim
Post by martynkim »
I'd say go with tubes just for the ride. A little more cushion :lol:
maddog
Post by maddog »
How about a make & model scoot :urban:
94cruiser
Post by 94cruiser »
maddog wrote:How about a make & model scoot :urban:
like my sig says 2000 SA50 SR
2000 Elite SA50
stock
I've had good luck with these. The SL26 90/90 fits for sure. Better traction and nicer profile than stock round-section 3.00s and 3.50s. Not much softer ride compliance, though. Some brands of 3.50 (Kenda, specifically) have been reported to fit the rear for ride comfort. Both 90/90 and 3.50 will need to be deflated to install the rim on the axle, then re-inflated. I currently have a Michelin S1 3.50 up front which I like too.
Bandit240
Post by Bandit240 »
Ive got a Kenda 3.50 on the back of my Aero 50 right now. Im thinking of the SL26's front and rear for it soon though. Will a 3x10 SL26 fit the rear of an Aero 50?
I use the SL26's on my Helix and like them there, ive also got Pirelli SC30's on my Elite 150. They are fine, but it may get SL26's too.
1986 Honda Elite 150 Deluxe
1991 Yamaha XT600
1993 Honda Elite 80
2001 Honda Elite 50
Pirelli SL26 in the 3.00 should be no problem fitting to Aero. I had that tire in the 90/90 size which is both taller and wider, on mine. Deflate to mount, then no fit issues. Fitting the larger 3.50 SL26 is unknown, if that's what you meant to ask. That one may be too tall.
losthope
Post by losthope »
does anyone know if the 3.50 SL26 fit on the 94-01 elite
