BBK on Spree and Oil Pump
Tuxedo
Post by Tuxedo »
So i have a Spree with the bbk and the oil pump, and ive been putting like 2 shots in every gallon for premix, is this good?
Saved
Re: BBK on Spree and Oil Pump
Post by Saved »
Depends on what you consider "2 shots"
I believe people running BBK premix are pushing 40:1 or 32:1.
In the barn::
2001 Honda Elite
2002 Yamaha Vino
2007 Roketa Sicily
2006 Ninja 250
Special thanks to:
Workdog & Iggysepia for parts & quick shipping.
Evilone for buying my SA50P.
Tuxedo
Post by Tuxedo »
with the oil pump on? 1 shot being 1.5oz
Tuxedo
Post by Tuxedo »
I have found it, its about 1:75 or so. :roll:
Fishman43
Post by Fishman43 »
Look up Wheelman's Flash IV build in the Scoot build section. I believe with the oil pump he is running 50:1 or 60:1 premix.
odinxxix
Post by odinxxix »
with my bbk spree i run the oil pump and i mix up 90:1 which is 1.5 oz of oil per 1 gallon of gas. the spree fuel tank is not a full gallon it is something like .66 of a gal so if you use the 90:1 mix in a seperate gas can first before you fill up.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
1.5 to 3oz/gal will get you around mid 30:1 to 25:1. Here's a link to the calculations and a small table.
http://www.hondaspree.net/phpBB3/viewto ... t=~#p96329
odinxxix
Post by odinxxix »
http://www.at-speed.com/air/oil_gas_calc.html
here is a link to a site that will help with the gas/oil ratio.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
