Primary or Secondary gears?
Which would you change?
Re: Primary or Secondary gears?
I like primary gears, but they don't have them in the gear ratio I like (9:1 or 8.4:1).
With secondary gears you have to remove the main cog from the final drive shaft, and have the new cog pressed on. Kind of a pain.
