Dio ZX af18e gears ratio HELP
MIkex24
Post by MIkex24 »
Hi. I want to change the ratio of my Super Dio JDM engine but i don't know what number of tooth i have to go with my engine to get 6.8:1 ratio. Any help would be appreciate... Thankss.. :|
sanjuro
Re: Dio ZX af18e gears ratio HELP
Post by sanjuro »
Buy the Polini primary gear set:
16:32 (2.000) (6.86 to 1)
...and that will take care of that. Daywot on eBay carries them.
MIkex24
Post by MIkex24 »
I don't want to go on primary gears as it is very expensive. What secondary gears have the same ratio (6.8:1) ?
sanjuro
Post by sanjuro »
You gotta pay to play.
MIkex24
Post by MIkex24 »
As you said i have to pay to play.. I want to tell me the difference of two gears set with the same ratio. Cheers
sanjuro
Post by sanjuro »
I'm not sure what you are asking.
MIkex24
Post by MIkex24 »
I asked you to tell me the difference between an expensive gear set and an cheap gear set both on 6.8:1 ratio.
MIkex24
Post by MIkex24 »
because you will never this answer i will tell you the difference. Just you pay more and if you believe that the more expensive parts it is better and faster your wrong...
Choosing the least-expensive option isn't always the best "deal". Surely the Eye-Talian pride of craftsmanship is some assurance that the alloy from which the gears are forged is up to the task. The machine work is likely to be more precise, and the resulting parts will fit better, run smoother and last longer. That said, I've heard no complaints of failure of the Made in Asia gearsets, and have some in Flash's tranny case myself. You do have to monkey with the spacing and shim washers with some brands.
So, Polini or Taiwan? It depends on how you define "value" and your budget. Italians do give away cool free Stickers. :wink:
sanjuro
Post by sanjuro »
MIkex24 wrote:because you will never this answer i will tell you the difference. Just you pay more and if you believe that the more expensive parts it is better and faster your wrong...
Woah, settle down there. Your written English is a little lacking, but now I see what you're asking.
If you were to buy the Polini primary drive setup all you would have to do is switch out the primary drive shaft, and larger gear cog on the countershaft. This should take all of 5 minutes once you have the transmission cover off.
For the 'cheaper' secondary gear set option you would switch out the smaller cog/spindle on the countershaft. The next step is a little more involved. Basically, you take the final drive shaft (the wheel attaches to this), and remove the larger cog attached to it. You then 'press on' the replacement cog from the aftermarket gear set. It is a little more labor intensive to get this done if you don't have the skills or equipment. Of course, outside labor costs $.
As-far-as quality, Polini has a long history of making fine parts. The Taiwan stuff is good if the quality control is there, but it's hard to really know.
So, please don't accuse me of being wrong, and act civil when seeking advice.
...and if you search eBay, I think Daywot has some taller gears (6.9:1)
http://cgi.ebay.com/ebaymotors/PRIMARY- ... arQ5fParts
MIkex24
Post by MIkex24 »
Ok but no one answer my question... Just see what i asked and if you can help just answer. Thank you
sanjuro
Post by sanjuro »
I just posted a link to the 6.9:1 gears ($75). The teeth aren't listed, but you can ask Daywot.
MIkex24
Post by MIkex24 »
the link you posted it is for PRIMARY GEARS
sanjuro
Post by sanjuro »
He has a set of 8.2:1 secondary gears at $65. It's not the gear ratio you want, and even if it was you'd be saving a whole $10. Get the primary gear set and be done with it. So I've given you two options, one at $150 and the other at $75.
You could also try vtcycles.com.
Mike,
You've seen our gear table - http://www.hondaspree.net/phpBB3/viewto ... =5&t=10334
Lowest secondary set on that chart is the 18/39 --> 7.58:1 ratio.
Theoretically speaking - if someone made a set of secondary gears at 19/38 that would be in your ballpark at 6.92:1. It's just no one's posted the availability of such a set.
