MSD blaster coil for Spree / Elite
Moderator: FAQ Moderator
Thats funny cuz i have the same stock number for my kit only i have the corsa which is better than the contessa, the elite-s & kimco zx share the same bore & pipes and only mallossi made a 65cc kit for the early model scoots but good luck finding one, i would contact that guy before you buy!
Darar: You need to read that listing more carefully. It says an Aero kit is available, but it is not a 70cc kit, it's a 65cc.
A quick look at the Aero engine case and a BoreArea*Stroke=Displacement calculation will show you that you cannot put a 70cc piston into a stock Aero block; it doesn't have enough clearance.
I believe the stock bore/stroke is the same for your vintage Elite as the Aero.
What's the piston diameter of the kit and the stock stroke of the engine?
I emailed the the guy off of ebay and here is what he said>
Hi, yes this Polini kit will fit your 1987 SE50 honda elite scooter. Yes it is the big bore 70cc kit-it is the biggest kit that is made for the SE50 scooter.
Please let me know if you have any questions.
patrick
808 221-4267
patrick
808 221-4267
