MSD blaster coil for Spree / Elite
Moderator: FAQ Moderator
OK, here's the manufacturer's link for the kit:
http://uk.catalogo.polini.it/en/pagina_710.116.html
Bore is 47mm, stroke is 37.4. BTW, I can't believe they shoehorned a 47mm piston/jug into the case, the jug skirt must be paper thin.
Now do the math:
Displacement = bore * stroke = (47/2)^2 * 3.14 * 37.4 = 64.8 cm^3
It's a 65cc kit, give or take.
This isn't exactly the first part vendor I've seen that doesn't know what he's dealing in. Always best to check with the manufacturer.
Now do the math:
