odd running in stock elite
skeeter2
Post by skeeter2 »
so I installed the engine that i received from bandit today into my elite. At first i couldn't get it to start at all. I checked for spark, fuel and compression, and everything was good. So i figured reed and switched them out with an extra set i had. I also switched the intake from an 89 which looks different than the 87. It started right up. Kinda... It idles like a * charm. When i give it gas though it sounds like an engine sounds when it hits the Governor. It revs slightly then bounces back down very quickly. Its the same with or without the air box. It almost seems like its running rich. I have the stock carb air box and an 88 jet. I cant think of anything. air leak maybe???
Videonut
Re: odd running in stock elite
Post by Videonut »
ya the air mix is not right, its what my spree does when the filter falls off. or check to see if there may be something stuck in the inlet hose or between the carb and engine. did ya put the right plug in?? is it getting starved for gas?? check the petcock too.
skeeter2
Post by skeeter2 »
Ok, i checked the plug, its right. I sealed the entire intake, and i made sure the air box had a good seal, new filter. i started it up, and i still have the same problem. it wont run if i give it more than 1/3 of gas. Im so frustrated. i want to drop round two of the polina kit on, but not if i cant even get it to run right stock. I've spent nearly $800 on this f-ing thing, and i havent ridden it yet......
PimpinSpree
Post by PimpinSpree »
have you cleaned your carb?
skeeter2
Post by skeeter2 »
:oops: honestly..... no. I didnt. I assumed that it was ok as it came off a running bike. I did however have it on my front seat to the scooter store yesterday. Will clean and report back....
skeeter2
Post by skeeter2 »
Ok cleaned the carb, and it hasnt made any difference. Im out of ideas.....
skeeter2
Post by skeeter2 »
problem solved! Used a different gauge, and i have 40psi for compression. Well that explains a lot. I just ordered another piston for the bore kit that was destroyed, so this is on hold until then.
