roller weights?
darat
roller weights?
Post by darat »
i now just have a stock eng on my elite. and i am running a 1000.rpm center spring and 9.5g weights but it seems a little slow off the line should i go with 8.5g
i need some input
maddog
Post by maddog »
Try putting a thin washer between the boss and the ramp and 8.5gr weights also sand the clutch bell with 60 grit, make sure the clutch pads are completely glazed, if all else fails go 1 step stiffer clutch springs.
lonelywanderer
Post by lonelywanderer »
never hurts to try... what kind of clutch springs do you have?
hrnytrtlsgsxr
Re: roller weights?
Post by hrnytrtlsgsxr »
darat wrote:i now just have a stock eng on my elite. and i am running a 1000.rpm center spring and 9.5g weights but it seems a little slow off the line should i go with 8.5g
i need some input
is it reving when you are coming off the line. Or is there lull before hand.Then as it starts reving you start to take off. If the later is the problem then i would lighten the poller wights total by 1.5 at a time.
sulfuraciddd
Post by sulfuraciddd »
lighten the weights and change that dam cluth springs
hrnytrtlsgsxr
sulfuraciddd wrote:lighten the weights and change that dam cluth springs
If it's bogging and you have to dethrottle and then throttle to get it going. Then change your center spring.
lonelywanderer
all good tips....
