werdhrnytrtlsgsxr wrote:as for the daytona I never saw it killing rollers on a nonstroke.Plus if you are gonna run the 15% i don't see the problem with the daytona.Just try it first so you don't have to buy unnecessary stuff.85stroka wrote:I guess I switch out the daytona ramp out to a sef at the same time
ZX DIO TRANS Conversion
- lonelywanderer
- lonelywanderer
- hrnytrtlsgsxr
then i would suggest that once you yet the weigth you want then use daytona or koso weight. they seam to last the longest. The malossi is good if you get the black rollers with the gold middle. it comes in a package of three.85stroka wrote:I running stroka, I think I my weights get flat spots pretty fast.
- hrnytrtlsgsxr
- lonelywanderer
- lonelywanderer
- hrnytrtlsgsxr
- sulfuraciddd
- hrnytrtlsgsxr
The black malossis if that is what you talkin about has the weight printed on the side.sulfuraciddd wrote:the black ones that you cant tell how heavy they are last pretty good too. but i wouldnt know because i change weights so often. even though they get flat i just sand them down till they round again and throw them bad boys back in because they brandnew now lol
- sulfuraciddd
nope not those i mean the ones from qfhrnytrtlsgsxr wrote:The black malossis if that is what you talkin about has the weight printed on the side.sulfuraciddd wrote:the black ones that you cant tell how heavy they are last pretty good too. but i wouldnt know because i change weights so often. even though they get flat i just sand them down till they round again and throw them bad boys back in because they brandnew now lol
- hrnytrtlsgsxr
its just dio weight thensulfuraciddd wrote:nope not those i mean the ones from qfhrnytrtlsgsxr wrote:The black malossis if that is what you talkin about has the weight printed on the side.sulfuraciddd wrote:the black ones that you cant tell how heavy they are last pretty good too. but i wouldnt know because i change weights so often. even though they get flat i just sand them down till they round again and throw them bad boys back in because they brandnew now lol
