Checkin in, first post... here at least
Chicago Ben
Post by Chicago Ben »
Hey everyone. Felt like saying what up. My name is Ben... some on here may actually remember I used to have a webpage called Ben's Honda Elite Page back in the day which was a small technical site as well.
Currently in Chicago. I have a 1995 Honda Elite S. De-rescricted (airbox, jetted, bored out exhaust, tied open oil pump, and have a POP pulley kit.. not sure what roller weights)
I basically just got rid of my car out here since it's not needed in the city where I live and work and brought my moped here not too long ago from home (Michigan)
Just sayin hey. Called up VT Cycles today to get some prices. Looking at probably doing a 72cc Malossi kit, typhoon exhaust, with a new gear set (believe he said 8.4:1 gears)
What do you guys think? Looking for a moped for stop and go city riding with crazy low end torque and top speed maybe about 55-60 mph max. :D
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
evilone
Re: Checkin in, first post... here at least
Post by evilone »
Hey Ben, them parts should do it. I'd go with 9:1 gears for city riding crazy low-end torque. If you go with the Malossi you will need to match the boost port in cases.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Chicago Ben
evilone wrote:Hey Ben, them parts should do it. I'd go with 9:1 gears for city riding crazy low-end torque. If you go with the Malossi you will need to match the boost port in cases.
Is there a writeup anywhere out there on how to do that port match?
Portage, MI eh? I went to WMU. You familure with the moped army dudes?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
maddog
Post by maddog »
what port match? or do mean case porting :naughty: install a polini or malossi kit as is :woot:
Chicago Ben
maddog wrote:what port match? or do mean case porting :naughty: install a polini or malossi kit as is :woot:
that's what I thought. That's what Kioni @ vt told me yesterday I wont need to do anything other than bolt on and ride.... (after break in obviously :smile: )
can anybody confirm this
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
evilone
Post by evilone »
http://www.hondaspree.net/phpBB3/viewto ... 9&start=45
Read through pages 4 and 5. The "case porting" to match the cylinder boost port is described there. Polini is bolt on but the Malossi cast iron has a bigger boost port. If you don't port the cases to match then the rear of piston might overheat and cause a problem.
I don't hang with the moped army guys, they look down on scooters :coolcruise:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Chicago Ben
evilone wrote:http://www.hondaspree.net/phpBB3/viewto ... 9&start=45
Ok so I just read through that and I understand how to port it but didn't trafficjamz do that because he was going with a bigger crank (stroker) setup?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
evilone
Post by evilone »
Nope, it's for the bigger boost port in his cylinder. Mini-stroker has nothing to do with it.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Post by evilone »
Can i get some back up here or let Ben blow up his expensive big bore?
The compressed charge from piston downstroke forces some of the charge up the boost port which cools and helps push spent gases out exhaust port (That is why the exhaust port is directly across from boost port). Drive to Portage and i'll port your cases.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Chicago Ben
evilone wrote:Can i get some back up here or let Ben blow up his expensive big bore?
May have to take you up on that offer haha. If I'm doing any case cutting at all, then why not go balls to the wall and go stroker/mini-stroker setup? or would that just be ridiculous for what I'm looking for? Realistically I was going to buy these parts little by little this summer and in the fall tear it apart for the 'rebirthing' of this thing so if I wanted to save for a stroker setup I could especially now I don't have my car. What do you think?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
so I talked to Keoni at VT again today and he stated that again, it is not necessary to port match with the setup I'm going with.
Not sure what to do here.
My Typhoon exhaust is on the way to Chicago. :2thumbs:
Question for everyone: can new gears be installed without pulling the engine off the bike?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
evilone
Post by evilone »
OK, i give up on the boost porting since i don't have any back-up, just be warned and i will be the first to say "told ya so" :wink:. Gears can be done without removing motor, you will need to remove muffler and rear wheel though.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Post by evilone »
Chicago Ben wrote:so I talked to Keoni at VT again today and he stated that again, it is not necessary to port match with the setup I'm going with.
So what setup are you going with, Malossi or Polini?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Chicago Ben
Malossi 72cc.. I even told him that 'guys on the forums' (not evilone from hondaspree.net haha) told me I should open up that boost port and he said his brother runs this exact setup with no issues.
I'm sure it can't hurt but what a pain in the * to pull this whole engine.
I still may do it anyway though. I want just a super reliable quick setup. I'm going to run the stock carb for torque just rejet and what not.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
also another question, he said this pipe is sprayed with clear. Has anybody on here grinded that off and sprayed with high temp?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
