Engine/piston work
dbouchard01
Engine/piston work
Can anyone tell me where to find detailed directions on taking apart the engine? I replaced the cylinder gasket but I am still not getting higher than 30 PSI for compression so I think a ring went evern though the cylinder is not marred or scratched.
Re: Engine/piston work
wait, did you replace the top(metal gasket)? and were you getting above 30 psi before?
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Buzzingbee89
Does it run? If it does, let it run for maybe 15 min. Piston rings expand as they warm up. So if you hook a compression tester to your motor you are going to get a low reading. Just from experience....
If it runs with a compression of 30 PSI it will be the first engine in history to do so.Buzzingbee89 wrote:Does it run? If it does, let it run for maybe 15 min. Piston rings expand as they warm up. So if you hook a compression tester to your motor you are going to get a low reading. Just from experience....
dbouchard01
No it does not run and I have the Honda Elite not the Spree. Thanks for the posts.
