Some interesting details
- Spreetography
- BMX
I was messing around with a rich-running condition yesterday, and looking for the notches on the slide-needle I noticed these differences between the '85 and '86 needles. I'm running the '85 carb, so I switched to the '85 needle. Slides themselves have no differences.
- showing 5 notches for 85
- 100_2418.jpg (51.97 KiB) Viewed 3473 times
- showing 3 notches for 86
- 100_2417.jpg (46.67 KiB) Viewed 3473 times
- '86 needle on left, smaller diameter
- 100_2420.jpg (54.97 KiB) Viewed 3474 times
"Great opportunities are often missed, being mistaken for work."
1985/86 Spree mixture
Re: Some interesting details
This is not news. The '84 and '85 have the 5 notches with #4 as stock and the '86 and '87 have the 3 notch needle and the center is stock. Going richer the both have only 1 notch to go.
the thicker needle on the right will run leaner between 1/4 and 3/4 throttle than the needle on the left.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
- Spreetography
- BMX
Ahh I see...I figured it was a known difference. So Im guessing... for '86,since the slide needle is smaller, therefor richening the mixture, and knowing the reeds are larger, the main jet is also probably slightly larger?
Nope, main jets are both #68, reeds should have no effect on jetting unless they change the size of the case, which they don't.
- Spreetography
- BMX
Im glad to know that, thanks Bear. It all makes sense now!
