rattle can paint help(colours)
- fightingplankton
so, i did a bit of research online, trying to find pearl white(the kind that sparkles w/ tiny metal flakes) in a rattle can.
i found the "metal flake" company but you have to have an air compressor and spray gun and all that jazz.
i went to home depot and they have blue metallic rustoleum...but not white.
i also found a company that does have pearl white, but it comes in those little tiny cans for painting model cars and would cost me about $40 just to do the 2 back panels...
any ideas on a brand of rattle can "metallic" paints?
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
Re: rattle can paint help(colours)
Dunno about Sprees, rattle cans, or paint in general. However I do know 'bout Pearl White.
The trick is to apply the white paint over black primer. In the right light, this gives a "Depth" to the white color you don't otherwise get. Metallic white paint is not the same as Metalflake white paint, if that's the look you're after. The latter might not come in a rattle can. The key to it all is like 10 coats of clear over all to give that "Wet Look".
- fightingplankton
place in the UK has it...sort of
http://www.specialistpaints.com/product ... pearl-canz
im looking for somewhere between that and this
closer to this aston martin "morning frost"
can be seen on car shown herehttp://www.rennteam.com/forum/page1.html?vs=9
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
some napa's can mix up rattle cans of touch up. might be worth looking into just find a automotive paint code. gl.
Red 85 Spree 87 afo5e swap, 3.5in rear tire, 9.8 to 1 gears, 43mph gps
01 Elite S 72cc corsa, 24 mm oko, pg long pipe, 8.4 gears 62.2mph @11000 rpm
Black\Red 85 spree stock
here is an option:
http://www.rustoleum.com/CBGProduct.asp ... sid=253611
1993 Elite - The Mad Max
if you must have pearl white, some automotive paint distributers can mix it in a pressurized can that can be re-used or try dupli-color 3 stage mirage 'rattle can" paint which changes color under light, 35 yrs ago we called it flip/flop
- fightingplankton
hmmm. the duplicolour mirage isnt exactly what i was looking for, but they have a product called "effex" that is. its a glittery clear coat you spray over your base...i may go down to my local shop and check that out. i know they have duplicolour there, but i'm not sure if they've got this stuff.
thanx for the tip maddog.
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
If you have a sherwin williams auto paint store in your area, they have paint with the metal flakes like you are describing. I think they have both rattle cans and in regular paint.
1985 spree 49cc offsets my
1969 mustang w/390 big block
- fightingplankton
i went to the local walmart today and found out something cool. krylon fusion now comes in "shimmer"
unfortunately, the white version isnt want i want. but if you want black or green it looks just like it does on new cars.
here's what i'm after
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
call maaco and see if they can mix that color and put it in the spray can. I can't remember if its that company or another one that does that.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
the duplicolor effex the clear changes color like the chamelaeon(sp) paint. but if you want black it looks like well black with glitter. i have the effex clear on my 2 hondas looks cool if you dont mind the color changes.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
- Goped
dupli color sucks. the (same) color varies wildly from can to can, and it is not a catalyzed paint, so the first time you splash a little gas on it you are going to see your paint going away.
