do these help at all? also, to marty: i didn't see any burnt wiring, but it's all wrapped entirely up in what appears to be electrical tape. should i..... unwrap? DUN DUN DUN.
They won't the way they are sitting in the picture, even if everything is good. You have to make the ground circuit by either bolting the rack to the frame of running a jumper wire between them. If they don't work then check the socket and the light itself.caito wrote:that's just the thing. the lights still don't work. at all.
Bear45-70 wrote:They won't the way they are sitting in the picture, even if everything is good. You have to make the ground circuit by either bolting the rack to the frame of running a jumper wire between them. If they don't work then check the socket and the light itself.caito wrote:that's just the thing. the lights still don't work. at all.
DO NOT do that. The that wire from the lights is green with a yellow strip, not a green wire. It is not a ground which is not a ground. Besidesodinxxix wrote:the rack looks broke where it would bolt by the seat. but in any event green is your ground. try hooking the green wire from the lights to that wire you said you seen hanging down. see if they work that way
That would do it. No ground = no lights.fightingplankton wrote:apologies for not seeing this sooner.
your problem is actually simple.
you're missing a wire that attaches to the tail light.
it goes down on that little tab that is part of the brass coloured ring at the base of your fixture. you can see the tab peeking out from behind the wires in the second photo.
all you need to do is get a bit of wire and run it from that point (solder if you have to) and attach it to the green wire in the first photo
ps. unlike the spree, the aero50 does not use the rack as ground. it has plastic around the whole light. there is a metal bracket that keeps it in place which attaches to the frame, but that's it.
