Steering Issues
Re: Steering Issues
flinthills76 wrote:Can you bend it back without screwing it up?
Yes but it is tricky
I welded a bottle jack to my frame to straighten it out
Re: Steering Issues
Post by eliteguy50 »
Or you can use chains and a high lift jack like this to stretch it out.
zuphilius
Re: Steering Issues
Post by zuphilius »
Trafficjamz wrote: The front forks don't need to be bent very much to get WONKY.
I prefer the term, "shapoopy" Maybe not as eloquent, but gets the point across, not that "wonky" doesn't.
Carry on. :b2t:
flinthills76
Re: Steering Issues
Post by flinthills76 »
Just to give you all a report on the 87 Spree. The forks were fine. The frame was bent. We put a chain on the back of the scooter attached to a car. We then put a ratchet strap on the front, then attached it to a tree and started cranking on it. we had to pull it back about 8 inches to original specs. It's now straight as an arrow and looks like it will be fine. The rest of the bike if in pretty good shape. We were missing the hose between the carb and air filter (I ordered one off here). We'll put it all back together today and see what it will do.
Thanks for all the advice guys. It's cool to see this scoot back from the grave!
Re: Steering Issues
Good job :2thumbs:
You saved a honda from the junkyard. :wink:
