im not sure what its from- the two arm clutch is on the left, and the standard spree clutch is on the right- any body else know or have any input??? the two clutches are virtualy the same except the difference in the ammount of arms on them-check the photos-any one have any ideas????yamahauler660r wrote:So, what's that 2 arm from?
spree clutch, and mystery clutch
- tha juggalo boss
- BMX
Re: Spree clutch
It is what it is-I drive a Cadillac-but I still love riding my elite!!
Re: spree clutch, and mystery clutch
The 2-puck is most likley from an sb50, the Elite E powerplant. If it's not, it looks just like one.
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Broken...
Spreeio
1987 Spree
- tha juggalo boss
- BMX
do you think swapping these clutches would make any difference? or at least using the two arm clutch to expariment with the spring tention???? im thinking if i shorten the springs a little to make the clutch enguage at a higher rpm, the two arm clutch would enguage a little better and mabe even a little quicker because the pads are much larger allowing for more of the pad surface to grip the bell housing, and also less chance of slipage- I know you guys put a lot of time and thought into your projects so i figure someone has probably tried it or can tell me why I shouldent-or should-Spreetard wrote:The 2-puck is most likley from an sb50, the Elite E powerplant. If it's not, it looks just like one.
- Trafficjamz
I have already done it.tha juggalo boss wrote:do you think swapping these clutches would make any difference? or at least using the two arm clutch to expariment with the spring tention???? im thinking if i shorten the springs a little to make the clutch enguage at a higher rpm, the two arm clutch would enguage a little better and mabe even a little quicker because the pads are much larger allowing for more of the pad surface to grip the bell housing, and also less chance of slipage- I know you guys put a lot of time and thought into your projects so i figure someone has probably tried it or can tell me why I shouldent-or should-Spreetard wrote:The 2-puck is most likley from an sb50, the Elite E powerplant. If it's not, it looks just like one.
You should do it, it works really good.
less slippage
- tha juggalo boss
- BMX
Trafficjamz wrote:I have already done it.tha juggalo boss wrote:do you think swapping these clutches would make any difference? or at least using the two arm clutch to expariment with the spring tention???? im thinking if i shorten the springs a little to make the clutch enguage at a higher rpm, the two arm clutch would enguage a little better and mabe even a little quicker because the pads are much larger allowing for more of the pad surface to grip the bell housing, and also less chance of slipage- I know you guys put a lot of time and thought into your projects so i figure someone has probably tried it or can tell me why I shouldent-or should-Spreetard wrote:The 2-puck is most likley from an sb50, the Elite E powerplant. If it's not, it looks just like one.
You should do it, it works really good.![]()
less slippage
Thanks!!! I appreciate the tip!!
- Trafficjamz
just swap the whole thing.
tospreornottospree Is running a elite e 48mm bbk. And he used dio grab springs in his elite e clutch.
They fit a little loose, but they seem to work so far.
do like i did modify some grab springs to fit it aint hard much better that stock
