possable clutch swap?
- tha juggalo boss
- BMX
im wondering if swapping the three arm clutch in my spree to an elite e clutch(same diameter) with two clutch arms would make any difference? or at least using the two arm clutch to expariment with the spring tention???? im thinking if i shorten the springs a little to make the clutch enguage at a higher rpm like ae86guy suggested, the two arm clutch would enguage a little better and mabe even a little quicker because the pads are much larger allowing for more of the pad surface to grip the bell housing, and also less chance of slipage- I know you guys put a lot of time and thought into your projects so i figure someone has probably tried it or can tell me why I shouldent-or should- thanks for any input!!
- clutch2.jpg (76.23 KiB) Viewed 3102 times
- clutch1.jpg (67.62 KiB) Viewed 3101 times
It is what it is-I drive a Cadillac-but I still love riding my elite!!
- tha juggalo boss
- BMX
Re: possable clutch swap?
spree clutch is on right, elite e clutch is on the left-
- clutch4.jpg (63.03 KiB) Viewed 3098 times
- clutch3.jpg (75.84 KiB) Viewed 3096 times
- Trafficjamz
I have done this swap. A lot less slippage.
Stock for stock or with the springs too? Thinking about just swapping the entire driven assembly...Trafficjamz wrote:I have done this swap. A lot less slippage.
- Trafficjamz
With or without the aftermarket springs, this is a good swap.eliteguy50 wrote:Stock for stock or with the springs too? Thinking about just swapping the entire driven assembly...Trafficjamz wrote:I have done this swap. A lot less slippage.
The two puck design just has more suface area.
