Trail Tech Vapor CHT problem
da808nanospeed
- Goped
got my Vapor install for couple weeks, works out fine, but I notice my cht always fluctuate when i was riding my scooter. the temp goes from 330 then drop to 230 then come back up, then eventually it quit and display no temp. I have to press the reset button then the temp will show again. did anyone encounter this problem with the vapor?
2003 Yamaha R1 998cc SOLD
1997 Honda Elite S 72cc SOLD
2007 SYM DD50 72CC X2
Goped sport 29cc
Goped sport 29cc
Re: Trail Tech Vapor CHT problem
Sounds like you have a faulty unit. Call Trail Tech's customer service and ask them is your best better.da808nanospeed wrote:got my Vapor install for couple weeks, works out fine, but I notice my cht always fluctuate when i was riding my scooter. the temp goes from 330 then drop to 230 then come back up, then eventually it quit and display no temp. I have to press the reset button then the temp will show again. did anyone encounter this problem with the vapor?
my temps fluctuate too but corresponds to opening and shutting the throttle. twice this weekend i had to reset it to get it to respond.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
01 elite 50
87 aero parting out
85 spree sold
da808nanospeed
- Goped
do you think is due to i extended the cht sensor wire, but i soldered wire, it shouldn't have any lost connection
Goped sport 29cc
Goped sport 29cc
i bought the extension and it still happened.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
01 elite 50
87 aero parting out
85 spree sold
do you guys have the power wire hooked up or just running off the battery in the gauge?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
power hooked up to ignition here.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
01 elite 50
87 aero parting out
85 spree sold
da808nanospeed
- Goped
tw39515 wrote:power hooked up to ignition here.
same here
Goped sport 29cc
Goped sport 29cc
so you have it hooked up where when you turn on the key,the back light comes on? try taking the battery out of the gauge and put it back in.I have 2 of those gauges and haven't had any issues like you guys are having nd I had my gauges for over 2 years. double check all your wire hook ups. double check the ground wire hookup too.
91 yamaha tzr 250r
91 yamaha tzr 250r
da808nanospeed
- Goped
I got the 48" extension and a new sensor. Now my Temp doesn't fluctuate anymore, works goodbakaracer wrote:so you have it hooked up where when you turn on the key,the back light comes on? try taking the battery out of the gauge and put it back in.I have 2 of those gauges and haven't had any issues like you guys are having nd I had my gauges for over 2 years. double check all your wire hook ups. double check the ground wire hookup too.
Goped sport 29cc
Goped sport 29cc
did you get it from trailtech? did you have to pay?
91 yamaha tzr 250r
91 yamaha tzr 250r
da808nanospeed
- Goped
I just email their tech support, the just send a new CHT sensor for free, then i request for a 48" extension, they also send it to me for free.bakaracer wrote:did you get it from trailtech? did you have to pay?
Goped sport 29cc
Goped sport 29cc
vette66_00
I have also had this same problem with the Vapor. Sporadic Temp sensor readings. Called Trail Tech yesterday told me to do a couple things, found out that the extension wire has a bad connection. They sent me out a new one after I got off the phone with them.. For a $100+ item there customer service is awesome willing to sit on the phone with you while you check measurements and test. I will be buying another one from them when it comes time.
89 Honda Elite E 48cc bbk and gears all broken in... I get to 35 mph (gps) full out and Im 240 lbs. Need more speed
My toy.. http://www.youtube.com/watch?v=LWgZXLUy25U
just got around to figuring out my problem. its a bad sensor too. i bought a trail tech tto, so had some parts to do troubleshooting. ill see what trailtechs gonna do bout sending out a new sensor.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
01 elite 50
87 aero parting out
85 spree sold
- Trafficjamz
Mine does that once in a while too.
(blank CHT)
Has any one figured this out 100%
