starter problems after instaling bbk
- speedfreek700
- BMX
hello. i put my 48 bbk on my spree and its running well. my starter motor wont turn the engine over fast enough to fire it up. anyone else have this issue? i tried the starter off my other spree also, same thing. i have 125 lbs compression. i did open my starter up to have a look and cleaned it out. my battery is holding well above 11 volts while im cranking.
its an 84 with no kicker, i think i will have to add kick start. what do you guys think? thanks chris
vette66_00
Re: starter problems after instaling bbk
Although I have a Elite E with kick start with the 48mm bbk. Mine did have a little bit of an issue starting at first but now into my 3rd tank of fuel it seems to be fine. It dose hesitate a little still when you first fire it up in the mornings. Also make sure your cables are cleaned well it will help get the amps to the starter.
89 Honda Elite E 48cc bbk and gears all broken in... I get to 35 mph (gps) full out and Im 240 lbs. Need more speed
My toy.. http://www.youtube.com/watch?v=LWgZXLUy25U
- Trafficjamz
speedfreek700 wrote:hello. i put my 48 bbk on my spree and its running well. my starter motor wont turn the engine over fast enough to fire it up. anyone else have this issue? i tried the starter off my other spree also, same thing. i have 125 lbs compression. i did open my starter up to have a look and cleaned it out. my battery is holding well above 11 volts while im cranking.
Get a kickstart ASAP.
Or find a place to add a second battery. Rebuilding the starter probably wouldn't hurt either.
- speedfreek700
- BMX
thanks for the input guys. i would like to have a kick starter. do i need to change out the front pilly for the kick star system?
- Trafficjamz
Yesspeedfreek700 wrote:thanks for the input guys. i would like to have a kick starter. do i need to change out the front pilly for the kick star system?
from an 86 or 87 spree.
battery charge should read 12.5-13.4
On what planet? A truely fully charged battery, sitting static should have better than 12.5 volts, so how will 12.5 volts charge it to full capacity? Battery charging voltage is 13.5 to 14.5 volts. Where do you get you information?maddog wrote:battery charge should read 12.5-13.4
- speedfreek700
- BMX
update on my starting problem. i added kickstart to get me going,after a tank of mix my electric start will now turn it fast enough to start. now im on to fooling with the carb to get her right. seems way rich with the 100 jet.
- Trafficjamz
What air filter are you using?speedfreek700 wrote:update on my starting problem. i added kickstart to get me going,after a tank of mix my electric start will now turn it fast enough to start. now im on to fooling with the carb to get her right. seems way rich with the 100 jet.
put a pod filter on it, and take the stock box off if you want to continue using the 100 main jet. i can get you a new k&n filter for 20$ shipped in a chrome color. let me know!
if you want to use just the stock box, rejet to a 95 see how that goes. do plug chops along the way too!
