Spree took a * need help
CarrotTop
Post by CarrotTop »
Motor seized up on me. Piston rings are broke.. Where can i get new rings?
2nd before they broke it had hard time staying running. What do you think caused this. Like it would start could rev it up but when it when come down and idle would die out.
az_slynch
Re: Spree took a * need help
Post by az_slynch »
If you need stock rings, hit up your Honda dealer. If you need a piston and rings, try Tazland's store:
http://cgi.ebay.com/ebaymotors/Honda-Sp ... leQ5fParts
I bought one of those before, quality part. He sells rings for the RIK pistons too, but note that they do not fit the OEM Honda piston.
'64 Vespa 90 (V9A1)
'65 Allstate Compact (DS60)
'74 Vespa 125 Primavera (VMA2)
'81 Vespa P200E (VSX1) (2)
'83 Yamaha Riva (XC180K) (2)
'84 Yamaha Riva (CV80L)
'85 Honda Spree (NQ50)
'86 Honda Gyro S (TG50)
'87 Honda Elite (CH80)
'89 Honda Elite E (SB50P)
toad772
Post by toad772 »
Well that is completely different then what I thought the thread was gonna be about. but you can get the rings here http://www.bikebandit.com (depending on year)
PS3 it only does everything.
az_slynch
Post by az_slynch »
While I recognize BikeBandit as a good source of parts, they don't list the NQ50 (Spree) or SB50 (Elite E). Not sure which models share rings with them.
'64 Vespa 90 (V9A1)
evilone
Post by evilone »
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
CarrotTop
Post by CarrotTop »
az_slynch wrote:If you need stock rings, hit up your Honda dealer. If you need a piston and rings, try Tazland's store:
Thanks i will have to double check the head make sure it did not get Damaged and the walls when i get home.
toad772 wrote:Well that is completely different then what I thought the thread was gonna be about. but you can get the rings here http://www.bikebandit.com/(depending on year)
haha thanks!
evilone wrote:http://www.cyclepartsnation.com/pages/p ... Honda.aspx
Both models are listed.
Thanks prob just order from them seeing as few places i called would have to order them in.
z50r-ghost
Post by z50r-ghost »
yep... i was expecting this thread to be about a different topic as well. i was really looking forward to reading it! haha! :bowrofl:
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
yamahauler660r
Post by yamahauler660r »
If a spree pooped it'd probably look like deer turds! :smile: :b2t:
My 2 wheeled bikes:
99 Elite S
97 Z50R
96 Elite S
89 Elite E x2
86/96 "Spree S/SpreElite"
87 Elite
86 Spree x4
86 Spree Special
85 Spree x3
84 Spree
83 Aero 80
80 XL250S
71 Trail 70 H
