Wrong oil added to tank.
SevenKeys
Post by SevenKeys »
I have an '86 Honda Spree which runs well. I added oil to the tank, but mistakenly read the manual and added sae 10-40 oil instead of the recommended 2-stroke oil. I only added 1/4 to 1/3 of a quart. Will this cause undo problems such that I should drain the oil and refill with recommended oil?
yamahauler660r
Re: Wrong oil added to tank.
Post by yamahauler660r »
drain it!!
My 2 wheeled bikes:
99 Elite S
97 Z50R
96 Elite S
89 Elite E x2
86/96 "Spree S/SpreElite"
87 Elite
86 Spree x4
86 Spree Special
85 Spree x3
84 Spree
83 Aero 80
80 XL250S
71 Trail 70 H
C3Killer
Post by C3Killer »
Just unplug the gas line from the carb and put a cup under it, then disconnect the vac line and suck in. Wait 1 minute until fuel stops flowing out the line, reconnect everything, refill with correct premix, and walla. Just don't suck on the fuel line. That wouldn't be good for anyone! (Well, except for us, that would just be down right funny.)
toad772
Post by toad772 »
C3Killer wrote:Just unplug the gas line from the carb and put a cup under it, then disconnect the vac line and suck in. Wait 1 minute until fuel stops flowing out the line, reconnect everything, refill with correct premix, and walla. Just don't suck on the fuel line. That wouldn't be good for anyone! (Well, except for us, that would just be down right funny.)
He said he added it to the oil tank so he isn't running premix.
PS3 it only does everything.
fastplastic
Post by fastplastic »
he never SAID oil tank but most sprees r stock so very good chance he has a working oil tank but to the question at hand should be a rubber line going to oil tank if in the case you did put the oil in there just pull off line drain refill
toad772
Post by toad772 »
fastplastic wrote:he never SAID oil tank but most sprees r stock so very good chance he has a working oil tank but to the question at hand should be a rubber line going to oil tank if in the case you did put the oil in there just pull off line drain refill
I misread it I guess.
wiguy05
Post by wiguy05 »
Take the scooter to a professional mechanic and have them drain the tank and bleed to oil injection system. You risk ruining a good engine if you attempt it yourself without knowing exactly what you're doing.
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
wiguy05
Post by wiguy05 »
Nope he did say oil tank "I have an '86 Honda Spree which runs well. I added oil to the tank, but mistakenly read the manual and added sae 10-40 oil instead of the recommended 2-stroke oil."
Evidently you are psychic if you knew which tank he was referring to from "the tank" :jack:
2006 Sachs Madass
- FTP 140cc Kit
- Lifan 90cc auto
toad772
Post by toad772 »
I reread it after posting that and I must have misread it the first time.
I read it and assumed it meant OIL tank too.
To assume it was premix would not make much sense. :crazy: sorry C3
If he was talking about the GAS tank, That would be way too much oil of any type. :shock:
SevenKeys wrote:I have an '86 Honda Spree which runs well. I added oil to the tank, but mistakenly read the manual and added sae 10-40 oil instead of the recommended 2-stroke oil. I only added 1/4 to 1/3 of a quart. Will this cause undo problems such that I should drain the oil and refill with recommended oil?
Did you run it with this oil in the tank? If not just drain it and refill.
wiguy05 wrote:Take the scooter to a professional mechanic and have them drain the tank and bleed to oil injection system. You risk ruining a good engine if you attempt it yourself without knowing exactly what you're doing.
That is probably not necessary .....It will not ruin you engine
It could foul out a spark plug or cause a little more carbon build up.
C3Killer
Post by C3Killer »
:worship:
wiguy05
Post by wiguy05 »
If there is an air bubble in the injection system it will very likely seize from oil starvation. To each their own.
2006 Sachs Madass
- FTP 140cc Kit
- Lifan 90cc auto
toad772
Post by toad772 »
Just got to bleed the system not hard.
fastplastic
i agree with toad, a good bleed call it a day, and to toad not trying to be a * just wanted to keep the facts straight so no one jumps to conclusions and gets off topic :thumbwink:
