Would you take your spree to a shop for this? Is getting the oil pump primed so complicated that you think sevenkeys coulod not do it if some one EXPLAINED it to him?wiguy05 wrote:If there is an air bubble in the injection system it will very likely seize from oil starvation. To each their own.Trafficjamz wrote:That is probably not necessary .....It will not ruin you enginewiguy05 wrote:Take the scooter to a professional mechanic and have them drain the tank and bleed to oil injection system. You risk ruining a good engine if you attempt it yourself without knowing exactly what you're doing.
It could foul out a spark plug or cause a little more carbon build up.
This forum is here to help people help themselves, not to point out other peoples mistakes.
