Checkin in, first post... here at least
Chicago Ben
Re: Checkin in, first post... here at least
you think that thing will be paint-able once the clear burns off or nah? I just don't want it rusting and looking ridiculous, not to mention high temp black looks stealth.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
High temp paint should work fine, i've done it with good results.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Chicago Ben
got bored and took some pictures of the Ferrari today
haha
you guys can see this bike has been dropped more than once (not me, never let people ride your moped, learned that a while ago) part of my project will be redoing all the panels
last but not least my beautifully custom done kick start delete (will be reinstalling my kick start on the rebuild)
haha
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
here is a quick vid of this bad boy idling
listen to that thing pur!! wow ! haha
http://www.youtube.com/watch?v=1MsOx1loVZw
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- sum-azn-kid
ouch lucky your beautiful pipe wasnt one when it went down. id be so sick if somebody droped my bike and messed up the beautiful $200+ pipe on it. btw are you still buying the malossi 72? i've heard many good things about that bore WHEN ported and case matched. their port design are better, so i've been told. if you wont drop in power with no cutting get the polini corsa. but hey if you have the tools and trust yourself or the person workin on you motor go for it. get done right the first time before you fry that good motor. good luck and lets see the pipe on the bike
zuma 125-sold
Ninja 250r-totaled
zuma 125-sold
Ninja 250r-totaled
Chicago Ben
gratuitous pipe + giant illinois plate picture
this pipe is loud
this pipe is loud
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
what kind of air filter options do I have with the stock carb? uni filter bolt up to the stocker?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
UNI makes a straight and a 15-degree angled filter with a 1" diameter donut. It fits.
Chicago Ben
which do you think would be best? keoni @ vt stated I should run my stocker carb if I want the torque with the 72cc malossi/8.4:1/pg typhoon setup.Wheelman-111 wrote:Greetings:
also... who even carries uni filters? does vt?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Does the stock carb offer enough fuel to keep it cool at an idle?Chicago Ben wrote:which do you think would be best? keoni @ vt stated I should run my stocker carb if I want the torque with the 72cc malossi/8.4:1/pg typhoon setup.Wheelman-111 wrote:Greetings:
Chicago Ben
apparently it does, keoni told me his brother runs this setupeliteguy50 wrote:Does the stock carb offer enough fuel to keep it cool at an idle?Chicago Ben wrote:which do you think would be best? keoni @ vt stated I should run my stocker carb if I want the torque with the 72cc malossi/8.4:1/pg typhoon setup.Wheelman-111 wrote:Greetings:
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
welp my girlfriend officially thinks im crazy
and....... here we go
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Really? I'm interested in the results.Chicago Ben wrote:which do you think would be best? keoni @ vt stated I should run my stocker carb if I want the torque with the 72cc malossi/8.4:1/pg typhoon setup.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Chicago Ben
really really. I am too. I'm going pretty slow on this project. I am going to be body filling the body panels and sanding and prepping. I plan on using bumper paint on all the unpainted plastic as well. I just ordered a new front fender from bikebandit... there goes another 74 bucks.evilone wrote:Really? I'm interested in the results.Chicago Ben wrote:which do you think would be best? keoni @ vt stated I should run my stocker carb if I want the torque with the 72cc malossi/8.4:1/pg typhoon setup.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
just bought a sr throttle cable from chopchop*123 aka tazland off ebay.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
