Found out what is slower than a Spree...
burnt_toast
Re: Found out what is slower than a Spree...
Post by burnt_toast »
Bear45-70 wrote: And that's why I use Seafoam with every tank full.
seafoam is great stuff :thumbsup:
projects galore :nerd:
Eft37
Post by Eft37 »
How much Seafoam are you guys running? I do 2-3 capfuls in in with every tank of gas.
Eft37 wrote:How much Seafoam are you guys running? I do 2-3 capfuls in in with every tank of gas.
Read the can. You are using way to much. They recommend 2 ounces per gallon of fuel.
http://www.seafoamsales.com/how-to-use- ... tment.html
Eft37
Post by Eft37 »
2-3 capfulls can't be more than 2 ounces, will measure it out later.
Eft37 wrote:2-3 capfulls can't be more than 2 ounces, will measure it out later.
2 oz is per gallon. If you have a Spree that would work out to about double the recommended dosage because of the .66 gallon tank.
Dude383
Post by Dude383 »
ALOW1 wrote:
Dude, have you ever had the jug off of it to check for carbon build up in the exhaust port? Another consideration is that your pipe has a lot of carbon build up in it?
Maybe it is time to have yourself a little bonfire.
Are you mechanically inclined at all? Even if your not we can still walk you through this.
Curious here, what kind of top speed are you getting out of your Spree?
Thanks for the kind words guys. When I bought it, the previous owner did say that the pipe was cloged up pretty bad due to the fact that the owner before him was using lawn mower 2-stroke oil and that was causing alot of build up in the pipe. He said he had cleaned it all up (did not mention how) and it ran much better. I've put three quarts of GN2 in it since owning it. Perhaps I need to go further with cleaning it out? Maybe I should try a little Seafoam and go from there.
As far as top speed goes, my speedo says about 33, but when I drive past a radar sign it says I'm going 29.
carp
Post by carp »
Tastes great too!!.....Sorry just chaught on to this thread.
Bear,he said "cap" full not "cup" full...haha..ha...OK back to reality.Isn't it about 2-3 cap full per oz.Wait.....hold on.......just went outside and did a quick measurement.3 oz out of a measuring cup=18 cap full(cap from a 16 oz Seafoam).So 3oz / 18 =.1666 oz. So 6 caps = 1 oz.So 6 -12 caps per gallon.Geez I need to put a lot more in.I've been doing the 1-2 caps too(saw that some place here on the forum).It just dawned on me your reasoning,all that 2 stroke oil (read carbon build up/deposits). Bear thanks for telling us how much is really needed.Carp
'98 sa50(thanks evailone),'95 sa 50,'86 spree(thanks wikked_spree57) ,'82 nu,'81 puch,'80 nc,(2)'78nc
'78 ranchero,'77 pinto wagon,'64 t bird,'48 ford tudor,'31 ford furdor
and they all need lots of love !!!
hwf-racing
Post by hwf-racing »
A lower combustion engine will def not burn your higher octane fuels, However, if your running hot it will cool your engine temps better aand also easy to jet. Derek
hwf-racing wrote:A lower combustion engine will def not burn your higher octane fuels, However, if your running hot it will cool your engine temps better aand also easy to jet. Derek
Image That makes absolutely no sense what so ever. It is obvious you have no clue about octane and how it works.
