85stroka wrote:Indeedhrnytrtlsgsxr wrote:no it's not. the only thing IMO thhat was better was a malossi single ring which they don't make anymore. or you could try a fabrizzi aluminum. Either way it will cost you some money. Corsas would be the best bet espacially if you just want to bolt up and go.diomike wrote:is the last link as goood as the corta. iam trying to get a good deal so i can do all the s... i want to my dio.
bore kite on the dio
- hrnytrtlsgsxr
- hrnytrtlsgsxr
- bitteraspects
gingerbreadman
- BMX
stillspeeding
gingerbreadman
- BMX
- hrnytrtlsgsxr
than you are one of the lucky few cause they don't make them any more and it has been awhile since they have stopped.gingerbreadman wrote:nah 6.8 malossizzzzzzzzzzzzzz only way for banggggggggstillspeeding wrote:Yea and a 7 to1 gear ratio- never use the stock carb for this combo 19mm/28mm carbs will save your investment!
stillspeeding
- hrnytrtlsgsxr
You can still get them here to it's also who you know down here too although i already have a set. But they are not available in the shops in hawaii anymore. Atleast not to the public if there is any left.If that was so then the shops would still be ordering them meaning they are not in stock at the dealer anymore. So what any shop or any person has now is all that there is.stillspeeding wrote:I can get them anytime- its who you know
