How much can a bad oil seal effect compression
toad772
Post by toad772 »
How much can a leaky oil seal effect compression.
PS3 it only does everything.
mopar4u
Re: How much can a bad oil seal effect compression
Post by mopar4u »
if your talking about crankshaft seals on a 2 stroke, you won't see a difference in compression. Compression only checks piston rings, cylinder condition and head gasket.
To properly check if an oil seal is bad you need to perform a leak down test. This test is very cumbersome on a 2 stroke. There are other tests which people claim work to test crank seals which I have little to no faith in. One is spraying carb cleaner around the suspect seal while the engine is running and listen for a change in rpm. Personally I think the seal has to be real bad for this to work.
If you do have a bad crank seal your engine will run lean :nervous: . You may notice eratic or high idle, bogging, white looking spark plug, gas/oil seapage from the seal area.
toad772
Post by toad772 »
I mean oil seals not crank case seal. If they do not effect compression then I guess something is bad in my top end. Will this http://cgi.ebay.com/ebaymotors/REPLACEM ... arQ5fParts fit my 86 Honda aero50?
Oh and my engine does not run I am working on getting it running has very little compression.
evilone
Post by evilone »
That linked piston fits your motor. The oil seals will not affect compression, most likely rings are bad.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
toad772
Post by toad772 »
evilone wrote:That linked piston fits your motor. The oil seals will not affect compression, most likely rings are bad.
Well time to take that head off then.
evilone
Post by evilone »
Good idea, hopefully you won't need a piston.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
toad772
Post by toad772 »
evilone wrote:Good idea, hopefully you won't need a piston.
Fingers crossed. :)
mopar4u wrote:if your talking about crankshaft seals on a 2 stroke, you won't see a difference in compression. Compression only checks piston rings, cylinder condition and head gasket.
You need to bone up on your 2 stroke theory. A 2 stroke pressurize the mixture in the crankcase and then feed the mixture into the cylinder UNDER PRESSURE. So a bad crank seal will effect compression. How much depends on how bad the seal is, but it will lower it for sure.
You also do not need to preform a leak down test to check the case seals, a leak down test only checks the cylinder and rings. You pressure and vacuum test a two stroke crankcase to check the seals. You car guys need to stop applying 4 stroke stuff to these 2 strokes.
mopar4u
Post by mopar4u »
Very rarely does a bad seal show up on a compression test. Compression tests are done to check the top end.
I'm not a car guy, I work and ride on snowmobiles all winter.
Perform a leakdown test/pressure test (whatever you prefer to call it) from the intake, not from the spark plug hole. Block off the exhaust. http://www.duncanracing.com/TechCenter/ ... sstest.pdf
mopar4u wrote:Very rarely does a bad seal show up on a compression test. Compression tests are done to check the top end.
I beg to differ with you. After 25 years as a 2 stoke mechanic, I can tell you that a bad crank seal sure as * will show up on a compression test. But then having been a factory certified 2 stroke mechanic makes my experience null and void according to you. I was doing crankcase vacuum and pressure test 20+ years ago, what were you doing?
toad772
Post by toad772 »
Well I will be taking them engine off the scooter tomorrow and bringing it down onto the work bench so I can work on it easier.
toad772
Post by toad772 »
The piston is toast and I don't know about the cylinder it doesn't have any gouges out of it but it does have like a bump on it in one spot looking form the bottom or the top you can see it sticking up a little bit. Will post pics later.
toad772
Post by toad772 »
Making new thread with pics
evilone
Post by evilone »
Bear45-70 wrote:A 2 stroke pressurize the mixture in the crankcase and then feed the mixture into the cylinder UNDER PRESSURE. So a bad crank seal will effect compression. How much depends on how bad the seal is, but it will lower it for sure.
Makes sense.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
