Hotwire
jlopez8
Hotwire
Post by jlopez8 »
85' Spree dont have the key need to hot wire it doest anybody know how to
toboggan
Re: Hotwire
Post by toboggan »
okay man, instead of posting a million posts, you should USE THE SEARCH OPTION
located in the upper right hand corner of any screen or page you go on, on this forum!
KingJeff801
Re: Hotwire
Post by KingJeff801 »
I know on my bike if I unplug the igniton I can kickstart it. Thats old skool 808 thieves use to undo the 2 ignition bolts and off you go, never did just heard about it :confused:
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
Re: Hotwire
KingJeff801 wrote:I know on my bike if I unplug the igniton I can kickstart it. Thats old skool 808 thieves use to undo the 2 ignition bolts and off you go, never did just heard about it :confused:
All these honda scooters are that way. Unplug the switch and the motor runs. You stop it with the "stop/run" switch HOWEVER you will have no tail or brake lights and the turn signals will not work and the gauges will be dead. The headlight will light though.
jlopez8
Re: Hotwire
Post by jlopez8 »
where the switch
martynkim
Re: Hotwire
Post by martynkim »
Cmon dude the ignition switch! :crazy:
jlopez8
Re: Hotwire
Post by jlopez8 »
im not good at this so can u give me instructons :thumbsup:
Re: Hotwire
jlopez8 wrote:im not good at this so can u give me instructons :thumbsup:
The ignition switch is where you put the key to make it run before. :eyeroll: :jack:
martynkim
Re: Hotwire
Post by martynkim »
You know that shiny thing that you are missing that goes into the slotted hole?? If you had it it would go vrrrooommm.
But, since you dont you need to unplug it. :nervous:
Re: Hotwire
At the ignition connect the RED and BLACK (not black with a white stripe) wires after you unplug it, So you can have taillights and blinkers.
fightingplankton
Re: Hotwire
Post by fightingplankton »
si9nce the 85 spree doesnt have kickstart you'll have to put a push button where the starter relay is to jump those wires.
mouse should be on in a bit to elaborate.
'86 spree
'86 aero50
'83 aero80
martynkim
Re: Hotwire
Post by martynkim »
fightingplankton wrote:si9nce the 85 spree doesnt have kickstart you'll have to put a push button where the starter relay is to jump those wires.
Dont forget to pull the LEFT brake lever
Re: Hotwire
Not if he jumpers the red and black wires, then the electrics will work normally.
Re: Hotwire
Responders on this board are sharp with electricals. :thumbwink:
Unplug the existing ignition switch, then add whatever switch you decide - key, hidden toggle switch etc. Wire as 'Jamz and Bear say. Normally open Red wire to Black wire connection is closed by your new switch, when you want the starting circuit and other Vbatt switched circuits powered (such as horn, taillight, brake light and starter relay). As 'plankton says, you need to make this connection to get your electric start to work.
You will need to be mindful to always turn your switch off after you kill the engine with the 'Run/Stop' switch. Otherwise, your taillight will deep discharge your battery while you are gone. Deep discharge will permanently suck life out of your battery.
86spreezy
Re: Hotwire
Post by 86spreezy »
Why post a thread like this when there lots of theives out there. Now they know how to steal honda mopeds
