Try using no air box and see if the acceleration improves. The 44mm big bore does not like the restriction of the stock air box no matter how many holes you put in it.rolinlowna96 wrote:ok i understand that i need gears to make it faster but with a new bore kit i should be going faster then 30miles and hr,,at least 35 it did 30 with out bore kit
If no airbox/filter is an improvement over swiss chees air box, get a uni filter, it should help.
Also check for carbon build up in your exhaust pipe. It might be time for the campfire treatment.
If you were going 30mph before you will still only go 30mph
What size tire do you have? What size is you friends tire?
Different year sprees had different gear ratios. Is you friends spree newer than yours?
Keep on rolling low.
