ok i have had this scooter for a while now but rode it off and on when i first got it but had a bad battery so i juss kick started it rode it like that till about a year ago until it locked up or so i though got bored yesterday tore into it and found just the kickstart mechanism is seized up so i started messin with it and was trying to get it to run after new battery it turns over freely tried to start once but cant get it to run i have cleaned the carb draind the tank checked the plug for sark and now im stumped yall know more than i do tell me what to try next
thanks in advance
98 elite 50 need help
Re: 98 elite 50 need help
ok well after fooling with it a little more the starter has gone out so i guess ill part it out anyone need anything lemme know ive got everything for it except mirrors im located in gadsden alabama and will ship on your dime
stopsign31
- BMX
I could use the gray plastic around the speedometer and the (hopefully) black piece of plastic around the headlamp. If in good shape, I could also use all of the front plastics. Let me know. (812) 779-6841.
1994 Elite SR (Black & Purple)
Tazland 51mm BBK (2nd kit -- fried the 1rst)
YMS- V8 pipe
9 : 1 gears Pirelli SL26 3.0 Tires
OKO 28mm carb // chrome CT manifold // Koso filter
Ruckus variator
Blue tension spring // 2K clutch springs
YMS- V8 pipe
Ruckus variator
