Looking for Exhaust pipe upgrade from stock SE50P
- Sasha's 87 Elite
- BMX
Hello, does anyone know where I can get an un-restricted pipe for my 87 se50p? I also need either a new carb setup or #85 jet and best air filter pod? Yeah, I am also planning on ordering from Daywot. (Kelly Variator and Ramp Plate)
87 honda elite 50
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
- fastplastic
Re: Looking for Exhaust pipe upgrade from stock SE50P
my buddy red spree has a leeovince pipe for his afo5e its sweet looking i would go with that but its a lil pricey at 150 but for a filter go with a uni filter they are awesome
- Sasha's 87 Elite
- BMX
LeoVince sounds like a cool pipe! Do you or anyone else know the part# for that particular pipe? and do you think it will fit my 87 elite?
Thanks, for the ideas!
87 honda elite 50
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
- fastplastic
i dont have the part number pm red spree for that but he has it on his afo5e swapped spree
- martynkim
Check the scootershop.com for the leo I have one on my 87 elite. They all come from overseas but well worth it in the end. Be prepared to to do some tuning on the trans though. Try this link. http://www.sip-scootershop.com/EN/Produ ... VINCE.aspx
- Sasha's 87 Elite
- BMX
Thanks for the replies, How many mods other than jetting and variator do you think I will need with the Leo pipe? BTW am missing stock airbox, but seems to run fair without it. Just have to clean the carb alot.
87 honda elite 50
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
- fastplastic
umm not the best idea though i would get that uni filter i was talking about asap
- martynkim
It will never run right like that and will run way too lean could damage the engine. Find a filter. Uni or custom box best is OEM.Sasha's 87 Elite wrote:Thanks for the replies, How many mods other than jetting and variator do you think I will need with the Leo pipe? BTW am missing stock airbox, but seems to run fair without it. Just have to clean the carb alot.
- Sasha's 87 Elite
- BMX
Yeah, I know I shouldn't run it w/o the filter
I actually was using a super cheap tecumseh paper lawn mower filter with some tape to seal
But I couldn't get it to rev very high at all. So I don't normally run it without anything to protect... Have had this elite 50 for 2yrs. Just slowly fixing and upgrading
Not to beat a dead horse, but who online sells the best UNI filter for my stock Carb?
87 honda elite 50
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
- Sasha's 87 Elite
- BMX
What else should I change out With the Leo SP3?
So, I am wanting to install the Leovince pipe on my Stock SE50P.
So far I am planning on Up Jetting for the best combination with pipe and Uni filter, Also need A variator and ramp plate, Since I got the Iowa model..
Thanks!!!!
Last edited by Sasha's 87 Elite on Sun Aug 29, 2010 2:36 pm, edited 1 time in total.
87 honda elite 50
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
79 yamaha DT 175
02 ZX6R
88 DT 50
94 Ninja EX250
- martynkim
This pipe is a cheaper alternative to a Leo Vince pipe. http://cgi.ebay.com/ebaymotors/85-HONDA ... leQ5fParts It will bolt right on and wont require trans tuning. Big bang for your buck. Uni filter should be easily found locally.
Check out this thread from when I was a noob about these bikes might help you out. http://www.hondaspree.net/phpBB3/viewtopic.php?t=12723
Actually at this point i went back to the stock aero unrestricted muffler with a k&n pod filter and a 90 jet it runs good doesnt bog. I couldnt get the lv pipe to run right with my set up at this point but marty has used one on his stock bore so it can be done. Look into a prodigy variator and weight set on ebay that will net you some more speed, maybe a new belt depending on how many miles are on it. Thats a nice looking elite congrats enjoy it...
Red 85 Spree 87 afo5e swap, 3.5in rear tire, 9.8 to 1 gears, 43mph gps
01 Elite S 72cc corsa, 24 mm oko, pg long pipe, 8.4 gears 62.2mph @11000 rpm
Black\Red 85 spree stock
Yeah thats the pipe Im using now it looks alot nicer because of tjams sandblaster and some fresh paint...martynkim wrote:This pipe is a cheaper alternative to a Leo Vince pipe. http://cgi.ebay.com/ebaymotors/85-HONDA ... leQ5fParts It will bolt right on and wont require trans tuning. Big bang for your buck. Uni filter should be easily found locally.
Marty you were a noob 8 months ago? your crazy...
that is a CLEAN elite!!!
- martynkim
red spree wrote:Yeah thats the pipe Im using now it looks alot nicer because of tjams sandblaster and some fresh paint...martynkim wrote:This pipe is a cheaper alternative to a Leo Vince pipe. http://cgi.ebay.com/ebaymotors/85-HONDA ... leQ5fParts It will bolt right on and wont require trans tuning. Big bang for your buck. Uni filter should be easily found locally.
Why am I crazy? I bought my 1st Spree last October.
