Something is in my muffler.
I took my muffler off to remove the engine and if I shake the muffler back and forth, I can hear multiple things moving inside but none are small enough to come out either end. Could it just be large pieces of carbon? I read all the time about cutting them open to clean them. Do I open it lengthwise and stop before I reach the neck that starts up to the engine or do I take it somewhere to get oxy-acetylene cleaned?
there's a cleaner I ve used before-works wonders,I cant remember the name,but I can give you the place I got it from -http://teamcalamari.com/
I bottle ,will easy do a spree stock pipe twice.
I think you gotta call cuz I dont see it listed, ask for the pipe decarb stuff
Remember,everyone is human,even if there stupid!
It's chunks of carbon.
You could cut it and reweld it just like you said, or torch-clean it. You could also just throw it into a hot fire for 10-15 minutes.
If there's a chemical that cleans these, I'd like to see it.
Admin, Hondaspree.net
- burnt_toast
