engine turns over no spark
biggkid2
Post by biggkid2 »
i have a 86 spree i put together from a few different sprees- no spark, question can i check the charging coil or pickup coil for resistance, if i put a continuity tester in the coil wire(plug wire) it lights up. i hve a charged battery, engage brake handle,have switch in run position, and - no spark. what should i test in the starting circuit and how. the harness looks good. thanks for helping the new guy!!!
0
Re: engine turns over no spark
axo
Post by axo »
Bear45-70 wrote:Manual is here with what you need to test the ignition.
http://www.hondaspree.net/other/Spree_part_a.doc
http://www.hondaspree.net/other/Spree_part_b.doc
That is the "owners manual"... not a "Service" one... the only electrical section is about checking the fuse.
I read on another thread a user posted useful information which actually described the procedure on checking the coils and everything... i will try to find it
1989 Honda Dio SP
AF18E - 82cc Taiwan kit - 24mm Oko - KRS pulley kit - Kevlar belt - 8.44:1 gears - 1000RPM Center spring - 7 grams roller weights - R1 sectional exhaust - 130lb pilot :)
Oops, :oops:
http://www.hondaspree.net/other/Spree_NQ50_84-87_1.pdf
If everyone read the titles to all the differnet forums on the Hondaspree.net they would find this and all the manual needs would be taken care of. :roll:
http://www.hondaspree.net/phpBB3/viewforum.php?f=11
veedubh20
Post by veedubh20 »
spree had bad cdi that why motor will not run. Just change cdi and motor will run. No mind the book! :naughty:
