Custom Pistons for mopeds
Re: Custom Pistons for mopeds
Lighter pistons will require a balance job, but the thing that I would be more worried about is wrist pin or compression height. Just because a piston is the same diameter does not mean the wrist pin is the same distance from the top of the piston.
Bear45-70 wrote:Lighter pistons will require a balance job, but the thing that I would be more worried about is wrist pin or compression height. Just because a piston is the same diameter does not mean the wrist pin is the same distance from the top of the piston.
Oh yeah, I know that the bore size is not the only spec to be concerned with.
What has to be balanced to go with a lighter piston?
I would assume (I know it is a bad thing) that the purpose of the lighter piston is to rev the motor quicker and higher. To make that happen and retain some reliability you should balance the motor. With my super stock motor we were not originally allowed to grind on the rotating assembly parts. The last 2 years I race in the Super Stock class we were allowed to balance since the motors were now out of production. My motor went from a max RPM of 7400 to 7600 with only the balancing. Maybe it was my imagination but the motor felt smoother too.
I understand in a multi piston setup, that the pistons need to weigh the same.
But what is there to balance in a single piston setup. :confused:
bakaracer
Post by bakaracer »
you can get ahold of wiseco and give them the specs you need. they can make a piston for you if you need
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
toad772
Post by toad772 »
Crankshaft.
PS3 it only does everything.
toad772 wrote:
Crankshaft.
:confused: Why would I need to balance the crankshaft if I change the piston? Isn't it already balanced :confused:
bakaracer
Post by bakaracer »
its really hard to balance a single piston 2 stroke crank
91 yamaha tzr 250r
bakaracer wrote:its really hard to balance a single piston 2 stroke crank
And that ia exactly why it is so important.
I still dont understand. :confused:
What needs to be done to the crank , if a different weight piston is used?
When you rev the engine faster and higher, any small imbalances are multiplied for every 100 RPM you add to the top end. Anyone doing it RIGHT is gonna balance the rotating assembly. It improves performance and longevity.
nickisaninja
Post by nickisaninja »
The counterweight on a crank needs to offset the weight of the connecting rod and piston.
If there is an imbalance say, 1gram, that gram gets multiplied exponentially with speed.
Say the piston weighed 1gram more than the counterweight. Every time the piston would be on it's downstroke the imbalance would push the crank into the case with more and more force coinciding with engine rpms. Every compression the piston would pull on the crank because the counterweight would not be able to cancel out the piston+rod+wristpin+retainingclips weight, since the counterweight is supposed to neutralize the weight of the rod and piston acting against the crank.
That's the best I can come up with. Make sense?
Epschoenly
Post by Epschoenly »
http://www.treatland.tv/vertex-47mm-tef ... piston.htm
Moped racers are using these. Food for thought.
nickisaninja wrote:The counterweight on a crank needs to offset the weight of the connecting rod and piston.
That does make sense......thanks.
