400 to spend on Dio clone upgrade?
Re: 400 to spend on Dio clone upgrade?
Quoth Epschoenly:
I suspected that a 26 would seem to be limiting,
I'm not so sure you can draw any conclusions from the diameter of the headpipe. By that yardstick, since it has a bigger header diameter, the Hot Surfaces exhaust should be more of a top-end pipe than the PG Long. For sure it isn't. There is a lot more to a pipe's performance characteristics than the initial diameter of the hole in the flange.
That said, the PG is among the best performing of the "affordable" exhausts I've seen. I have not tried it, but I'd be surprised if the one in the JW kit even comes close. VT can ship you the PG Long for about $150 or so last time I asked. Worth every penny if you axt me.
Epschoenly
Post by Epschoenly »
I suppose I am simplifying a bit, I am used to looking at expansion chambers, these muffler type pipes are different, and since they all essentially look the same it is hard for me to ge them all straight.
I suppose I'll go ahead and ask why more people are t running expansion chambers? Although I imagine the muffler still acts a bit as an expansion chamber.
Also which Pg pipe are you referring to?
Post by eliteguy50 »
Epschoenly wrote:I suppose I am simplifying a bit, I am used to looking at expansion chambers, these muffler type pipes are different, and since they all essentially look the same it is hard for me to ge them all straight.
I run the sectional J type pipe because I want the pull to start right at the bottom end and I don't need to scream out at 10k+ RPMs. The PG (Phongeer Long exhaust) runs similar to an expansion chamber for power band RPM's but not as loud as some expansion chamber pipes.
