1986 honda spree 48mm bbk install,lost a little top end??
ascmlaren53074
Post by ascmlaren53074 »
hi i have a 1986 honda spree just had the 48mm bbk installed ,it seems to accelerate quicker but seems like i lost a little top end from 31 to 28 mph, but also it sems like when i floor it all the way it loses a little power but when i ease back on it just a hair it seems to gain a little, whats up with this??(just had the bbk installed a few days ago. thanks
1986 spree,48mm bbk,2.75 rear tire,aero 50 front turn signals,1987 front glovebox add on,uni pod filter,taz's gear set on the way
Re: 1986 honda spree 48mm bbk install,lost a little top end??
Vacuum leak somewhere or a fuel restriction in the carb or fuel feed system.
tazland001
Post by tazland001 »
Could be the 100 jet is a bit rich. Might want to try a 90.
Taz
Yeah, or the 100 could be too lean and he needs a bigger jet with his setup. He doesn't mention exhaust or intake setup at all. What does the plug look like after running this thing at speed?
tazland001
I agree the plug is a good place to look. You took the words right out of my mouth Bear. lol
Taz
zuphilius
Post by zuphilius »
Isn't there a break-in period when installing this? He says he just put it on a few days ago.
True and with that in mind, COMPRESSION CHECK!
ascmlaren53074
break in is crutial i will wait a couple more weeks and finish the break in period i did not mention that the mechanic took the foam air filter all the way out and dis carded(not sure why he threw it away) would that help a little if it had the air filter back in???? thanks guys for all the replys
evilone
Post by evilone »
ascmlaren53074 wrote:break in is crutial i will wait a couple more weeks and finish the break in period i did not mention that the mechanic took the foam air filter all the way out and dis carded(not sure why he threw it away) would that help a little if it had the air filter back in???? thanks guys for all the replys
Yes, you're probably getting too much air now. Bear saying the 100 jet might be too small for your setup would be correct.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
patthesoundguy
Post by patthesoundguy »
I certainly wouldnt want break in a big bore kit with no air filter.
ascmlaren53074
i agree, not going to ride it til i get my air filter put back in
The mechanic likely found the filter crumbling in his fingers. My 2001 was doing that when I first purchased Flash 3. The stock engine tried to inhale a chunk of it, producing an early stall scare.
Hopefully a new stock replacement can be sourced. If not, you can try a heavily-oiled UNI 1" pod with that 100 jet. The small Pilot circuit built into the stock carb may remain an issue.
ascmlaren53074
i found a nos filter on ebay just bought it :2thumbs:
You are using the stock airbox on a 48mm bbk? :eyeroll:
That would be your first problem.
ascmlaren53074
yes but it had holes drilled in to the top as per the instrutions, but i tried to used a small cone oil breather filter fastned it to the carb and the moter sputtered and missed when you gave it throttle but hooked it back up to the stock air box and it ran better
