needle clip setting?
evilone
Re: needle clip setting?
Post by evilone »
ZMUD wrote:I did forget to metion that there is a decent amount of smoke and start up
:bowrofl: Oh s***! "IT MIGHT BE THE D*** OIL PUMP" :bowrofl:
tw39515 is the one who mentioned the oil pump and it's starting to look like his troubleshooting skills might be better than yours :shock:. Anyways, i agreed since my wifes elite does the exact same thing...starts, runs a little crappy while smoking more than usual, can hardly give it much throttle, then clears up and runs great.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
With incomplete info from the OP, it becomes a matter of luck and that never proves who is a better diagnostician. You notice that he NOW says it smokes. Gee who said, if it was an oil issue it would smoke?
ZMUD
Post by ZMUD »
Sorry about not telling about the oil smoke just assumed.This is not a daily driver. I might ride it every weekend. I did put the split throttle/oil cable on and this was the restricted model elite"s". Could that have affected the oil pump in anyway?
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
1"uni-filter,Keli 9g
1k center,8.44 gears,ZX Trans
V8 Pipe,IRC MB38 80/90 tires
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
1" Uni-Filter,8:44gears
tw39515
Post by tw39515 »
Im not here to argue, just to help people out and not talk down to them. no the cable shouldnt have any thing to with it as long as it is adjusted properly.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
evilone
Post by evilone »
tw39515 wrote:Im not here to argue, just to help people out and not talk down to them. no the cable shouldnt have any thing to with it as long as it is adjusted properly.
Same here, I was just in the mood to give Bear a hard time today. I'm done.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
tw39515
Post by tw39515 »
mee too.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
It is not arguing if you are wrong with your premise and another corrects you. d***, you all act like a bunch of 8 year old girls with oh so tender little feelings. :eyeroll:
tw39515
Post by tw39515 »
like i said im done :b2t:
and i was not wrong.
87 elite dio
01 elite 50
87 aero parting out
85 spree sold
There you go, Never wrong. Are you part of the obama admistration too?
You were wrong because you were guessing oil when infact there had been no mention of an oil issue. :eyeroll:
S4Patrick
Post by S4Patrick »
Bear, after reading this entire thread, I've come to the conclusion that you have rather poor presentation skills. You're the one with the defensive stance, as well as making several assumptions. Most of what you have "contributed" is attitude, a bit of unwarranted anger, and is flat-out childish. YOU seem to know a great amount of things, it's your overall presentation/ communications skills that YOU should work on. Why such hostility and anger?
This is a forum where we all share ideas, knock off the anger/ attitude.
And don't reply with some BS attitude. Just keep it to yourself. :crazy:
'92 Super Dio ZX - AF18 Corsa
S4Patrick wrote:Bear, after reading this entire thread, I've come to the conclusion that you have rather poor presentation skills. You're the one with the defensive stance, as well as making several assumptions. Most of what you have "contributed" is attitude, a bit of unwarranted anger, and is flat-out childish. YOU seem to know a great amount of things, it's your overall presentation/ communications skills that YOU should work on. Why such hostility and anger?
Again you miss the point. The OP said Nada, zilch, nothing about excessive smoke in his original post and to jump to an oil issue shows NO troubleshooting skills what so ever. I did say that excessive smoke would be present if it was actually an excess oil issue, but you all ignore that an pretend to know what you are talking about. I made a living troubleshooting 2 strokes for years and the logic used in this thread would get you canned from the job ASAP. I still don't think it is an oil issue, because almost any 2 stroke will smoke more than normal on start up because as the fuel in the engine evaporates due to residue heat, the oil remains. And that oil has to be burnt off on the next start up. You can say what you want but I've fixed more 2 strokes than 99 persent here and got paid for it, I do know what I'm talking about.
It is actually your attitude that stinks, as you really have no basis to question my abilities or knowledge. It is not my mission in life to kiss any little whinner's *. If they don't like the facts and the truth, then go the * away and shut up.
S4Patrick
Post by S4Patrick »
Bear, it's you that needs to shut up. Good Gawd, all the hostility and defense....NO one's questioned you or your capabilities--as you make some very valid points. Stop making this a personal thing. It's your *-poor attitude & overall negative demeanor that would get you fired from any job. NO one's asked you to do *, Bear. Calm down.
S4Patrick wrote:Bear, it's you that needs to shut up. Good Gawd, all the hostility and defense....NO one's questioned you or your capabilities--as you make some very valid points. Stop making this a personal thing. It's your *-poor attitude & overall negative demeanor that would get you fired from any job. NO one's asked you to do *, Bear. Calm down.
I'm only hostile to nitwits that THINK they know something when they nothing but actually think they deserve respect just because they exist. Well guess what, only in your twilight zone PC world does that happen and regardless of how much you wish for that fantasy, it does not exist. Al
I'm only hostile to nitwits that THINK they know something when they nothing in reality but then they actually think they deserve respect just because they exist. Well guess what, only in your twilight zone PC world does that happen and regardless of how much you wish for that fantasy, it does not exist. Also if you care to check, in this country, no where is it guaranteed you will get respect and nothing is said anywhere about keeping your tender little feelings from being hurt. I won't kiss your butt and talk nice to you. My attitude is * poor because of all the whinny little cry babies on the internet. Oh and if you are really as slow on the up take as your and your ilk appears to be, I don't care what you think about me and my ways and I sure as * am not gonna do anything you tell me to do.
Locked
